Need help with Tranny Cooler lines
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazin Ed, Sep 6, 2002.
  1. Blazin Ed
    Blazin Ed Registered Member
    Mar 29, 2002
    92
    Seattle
    Tommorow I'm planning on installing a tranny cooler on my '88. Of the 2 tranny lines going into the radiator which one should I take off and run through the cooler?
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i would plumb it on the return line. less pressure, it will get cooler in the radiator (which obviously also has the water, so it stays pretty hot) then to the exteranl line to cool it off much more.
  3. Blazin Ed
    Mar 29, 2002
    92
    Seattle
    Forgive me! How can I tell which one is the return line? Is it the bottom or top line going into my radiator or something I can check coming out the tranny?
  4. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    The info you need can be found at this page on TCI Automotive's Website. They have cooler line info on most transmissions there.
    Since this seems to be a common question, I just posted the link so others can look for their trans setup, too. /forums/images/icons/smile.gif
