Need help with U-bolt ordering
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sammy, Aug 15, 2002.
  1. Sammy
    Sammy 1/2 ton status
    Dec 8, 2000
    250
    Right now, in front of me is a catalog of the Black Diamond U-bolts. I have 2 options.
    4WD 1/2 Ton Pickup, Blazer, Jimmy (2-3/4 front axle) 73-87
    4WD 1/2 Ton Pickup, Blazer, Jimmy (3 front axle) 73-87
    I have a 88 with a 10-bolt front. What do I order.
    I wish I just could take my old U-bolts and go to the place to fit them, but they don't have um on stock.
    Thanks in advance.
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    If you can get the actual dimensions of the U-bolt, you will need a 5/8" diameter bolt, with a 3" ID between the legs with a length of 8". The one that goes around the differential housing will be a 5/8" diameter, 3.25" between the legs, and 10" long.
    (3) 5/8" x 3" x 8" U-bolts
    (1) 5/8" x 3.25" x 10" U-bolts
    I couldnt find a 10" locally, so I bought a 12" and after it was installed, I cut off about 2" with a torch.
    Hope this helps.
  3. Sammy
    Dec 8, 2000
    250
    Is it possible that the D44 that to my best of knollage used to be standard in the front before the 10bolts, is 2-3/4 inch across. I guess for a relation between your mentioned 3 inch, and the 3 in the last U-bolt kit I mentioned.
  4. outlaw612
    Feb 11, 2001
    2,342
    The D44 was used as a front axle prior to the 10 bolts, but both of these axles use the same U-bolts.
    I would say youre correct kit would be the 3" kit you mentioned.
