Need help with ubolts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, Sep 19, 2001.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I'm having trouble getting the ubolts to fit in the spring plate. The ubolts are a little bit wider than the holes and I can't hold everything in place and squeze the ubolts together to make them go. Any helpful hints on how to make it easier?
    89 K5 Silverado
    <a target="_blank" href=http://mudfrog.rockcrawler.com>http://mudfrog.rockcrawler.com</a>
  2. Ross
    Ross Registered Member
    Apr 19, 2001
    75
    IL
    the same thing hapened with me and i used a locking clamp thing to make it fit
    <font color=orange>1986 white K5 4" lift and 35 BFG muds</font color=orange>
    <a target="_blank" href=http://www.community.webshots.com/user/1986k5>http://www.community.webshots.com/user/1986k5</a>
  3. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    I used a C-clamp to pinch the obnoxious things together.
    <a target="_blank" href=http://community.webshots.com/user/thatguydrew23>http://community.webshots.com/user/thatguydrew23</a>
  4. flblazer
    flblazer 1/2 ton status
    Nov 24, 2000
    149
    tampa fl
    i used a redfish to do mine heheheeh
    can some 1 find me a ford i need to take a pee still peein on that ford just have to keep goin dam i can not stop pissin:) k5s kings
  5. buzzk5
    buzzk5 Registered Member
    Aug 30, 2001
    29
    gimli,mb,ca
    been there did that had the plates on wrong....tried to bolt em on sideways ..scarry thing is it worked...
    Dave
    80K5 on ice
    are they all spinning?????
  6. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    267
    Salem ,Or
    Scary thing is I just put a used lift on and they didn't fit, but today when I did the add-a-leaf they fit perfect. Must have bent over the week, but first I had to use the C-clamp.
    Displacement, cubes, and did you say you drive a riceburner???
  7. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    I've done th C-Clamp trick before and it works, but I had another person helping me.
    Another technique that works, is to put the nuts on the ends of the U-bolt, and then put the U-Bolt in a vise and crank it down just enough to bend it a little. Use the nuts on the ends so you don't flatten the threads on the bolts.
    I did it this way when I bolted my D44 in because I was by myself and couldn't hold everything, including the C-Clamp, by myself.
    Thomas.
    -- '84 K5 Blazer --
    <a target="_blank" href=http://stoopalini.off-road.ws/blazer>My Blazer Site</a>
  8. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Cool... Thanks guys I'll give these ideas a go when I get home from work tonight.
    89 K5 Silverado
  9. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    I easiest way I have done this was to use large channel lock pliers. Just have a buddy squeeze the ends together and then just slide the plate over the top.
    74 Blazer
    Zepplin
    Check out my Blazer<a target="_blank" href=http://community.webshots.com/user/zepplin1976>http://community.webshots.com/user/zepplin1976</a>
