Need Help With Water Proofing Starter
Discussion in 'The Garage' started by teamgerth, Feb 21, 2005.
  1. teamgerth
    teamgerth Registered Member
    Sep 1, 2003
    57
    Hubbard, OR
    Does any one know how to water proof a starter. Every time I go wheeling in the deep mud I burn up a starter by getting mud and water in it. THANKS
  2. short sub
    short sub Registered Member
    Jan 17, 2005
    98
    Sealy Texas
    im assuming this is for a sb chevy if so try this one day. go to a part store and ask to look at a typical starter for a 80's small block- then look at one for a 96 or up chevy with a vortec 5.7 and pay close attention to the nose cone where it hits the flywheel. the newer style is alot smaller and doesnt let nearly as much mud and muck within. then ask them to put them both on the starter tester(if applicable) and listen to the difference btwn the two. the vortec one is gear reducted and turns over alot easier also, so that was my solution to saving starters. i have ran the same one for around 2 years now and im very happy with it. u will need to use shorter bolts though since it is such a smaller starter but i assure you it will work. well hope ive helped ya lata ryan
  3. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    The flywheel changed around 1982, nit sure when. I put a 1971 350 in my '82 K-10 a long time ago, purchased a starter for a '82 and ruined about 30 teeth before I could get my fingers off the key switch. Number of teeth is different or sumthin'. Had to replace the flywheel. "The flywheel changed around 1982" is what my older brother (Chevy salesman) told me at the time.
  4. teamgerth
    Sep 1, 2003
    57
    Hubbard, OR
    I have a 12:1 427 bbc with a 168 tooth flex plate, will that starter work for that flex plate. I am currently running a 4.4:1 nippondenso style starter and burn it up every time I hit the deep mud holes. It does't have a nose cone.
