Need help with what timing to run with my cam....
Discussion in 'The Garage' started by Silver84k5, Sep 21, 2002.
  1. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    ok im running a comp cams offroad cam, part number CCA-12-235-2 Duration@ .50" Intake 210 degrees 218 degrees Lift .447" .462" this is copied straight out of summit catalog so if you need more info i can tell you, im running a stock Rochester Quadra Puke.......
  2. florida4x4
    florida4x4 1/2 ton status
    Sep 9, 2002
    255
    Florida
    12 degrees initial, 35 deg. by 2600 rpm... but seriously you need to find out what the engine likes. Start by getting the jetting correct and then play with the timing curve /forums/images/icons/smirk.gif
  3. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    yea im trying to learn how to tune my carb on my own, i got no tach right now, i have it at 14 right now and it seems to be ok, it was kinda dogging when i had it 12
