Need help with wiring an alternator...
Discussion in 'The Garage' started by Poohbair, Feb 9, 2006.
  1. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    My buddy swapped a 94ish LT1 in his FJ 40, and has an aftermarket harness for the wiring. He cant seem to get the alternator to charge the battery, so we are looking for a little advise on where to wire these things to. None of the wiring diagrams have the same color wires as what he has. The alternator plug only has 3 female connectors, but the alternator has 4 male prongs...?
    The alternator is of the hi-amp option, or so he was told by the wrecker he bought it from. The wire labels for the alt plug (from top largest wire down in the picture) are: S F L P (P doesn't have a wire, but there is a prong in the alternator for one).
    Anyone know how to wire this bitch?
  2. goldwing2000
    goldwing2000 Guest
    Yank it out and trade it in for a two-wire plug! :D
    I would guess S is signal and F is field but I can't think of anything for L. Load? Those alts only came on computer-controlled cars, so it may not work without the right ECM.
    Have you tried a google search?
  3. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    something to search here is the pontiac trans sport upgrade... same alternator... I couldnt get it working in my truck, however I believe I may have a bad alt from the junkyard..... but will be revisiting this soon....
  4. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
  5. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    red goes to hot, white goes to guage, big bolt on back of Alt goes to battery
  6. goldwing2000
    goldwing2000 Guest
  7. dyeager535
    26,980
    So in other words, the wires can be cut and spliced with the connector he already has. That picture is perfect. :)
  8. Dallin
    Dallin 1/2 ton status
    Feb 12, 2003
    135
    The alternator is a CS144. It doesn't need a computer.
    S terminal is the sense wire. Hook it up to the positive battery terminal or after one of the fusible links.
    L terminal turns the alternator on. It needs a 35 to 300 ohm resistor in the line and should be switched on with the ignition. You could use a small lightbulb in place of the resistor.
    You probably won't need to mess with the other terminals.
  9. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Sweet guys, thanks for the info... he is trying to get this thing up and running by next weekend to go wheelin!
    Here is a kinda old pic of what the engine is in...It is alot more put together now!
  10. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    So lets revisit this, I just got one for my 6.2 truck. I went to napa and bought a pigtail for it, with three wires, on is larger (about 12 or 10 gauge) and red, and the other two are around 16 gauge and one is brown and the other is white I think. So it soungs like the large red wire loops around to the screw terminal on the back of the alternator but I am not clear on how the other two leads hook up.
  11. Dallin
    Feb 12, 2003
    135
    You've got the red wire figured out. Wire the white wire to a ignition switched source with a 30 to 300 ohm resistor in the line or a light bulb. Don't use the brown wire.
  12. afroman006
    Aug 21, 2002
    2,876
    Good deal, thanks.
  13. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Holy big pictures Batman! :shocked: Check out www.irfanview.com for some sweet FREE software for resizing pics. :)
  14. RootBreaker
    Nov 29, 2001
    5,118
    173
    hellz all ya need to do is use mspaint :haha:
  15. goldwing2000
    goldwing2000 Guest
