Need help! wont start!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by big75jimmy, May 16, 2003.
  1. big75jimmy
    big75jimmy Registered Member
    Jun 26, 2001
    77
    Kirksville MO
    I recently rebuilt the 350 in my '85 ,got it put in, wired up, etc. and now it wont start. It has spark, and is
    getting fuel, cranks over like normal, just won't start. Did I do something wrong? or? need help
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Well, if it's getting spark and fuel, it must not be getting spark at the right time. Check the timing/rotor location once more.
  3. Grim-Reaper
    7,385
    Atlanta
    bet the distributor is 180 out. common problem after a rebuild. When you put the timming chain on with the dots on the gears facing each other your not on TDC Yes the # piston is TDC but it's not on the compression stroke. Lift the distributor up and spin the motor one turn back to TDC and drop the distributor back in. Set timing about a 1/4 inch before #1 on the distributor. Should fire right up.
