need help
Discussion in 'The Garage' started by 1979jimmy350, Sep 18, 2004.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    i need to know how to hot wire a 1976 cutlass my buddy lost his keys and is fifty miles from home what can i do
  2. dyeager535
    26,980
    Not sure if the columns are the same as ours, but to not destroy it, you have to pull the wheel and the lock plate...have to get the pin out of the way that locks the column in one place. Either that or bust the column on the drivers side opposite the key and worry about trying to replace it later. Hopefully its not metal, the truck column ones are plastic.
    After that, run the coil wire on the distributor to 12 volts, and jump the terminals on the back of the starter until it catches. If thats on Olds motor, not sure you can do that, the single exhaust crossover piece is probably hiding the starter, as is the heat shield. Might be able to get something in there to jump it though.
    More work than getting a key made I guess.
  3. 77crewcab
    77crewcab 1/2 ton status
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Crawl under the car with a screwdriver and jumpt the terminals on the starter. You may need to pump the gas a couple times first depending on how well the car normally starts. Or you can use one of the remote start switches but it does the same thing. Locked my keys in the trunk of my car at the mall once on a 110 degree day and had my 6 month old son with me so I got creative really fast.
