NEED HELP!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KING K5, Jul 17, 2001.
  1. KING K5
    KING K5 1/2 ton status
    Sep 28, 2000
    172
    Sacramento, Ca.
    I have an '81 Blazer with 5.7L 350 and my Coolant/water is running/leaking down my passenger side floorboard from the firewall (inside cab) and from the engine compartment it looks like it's leaking from somewhere under my A/C unit which is installed but not wired up so I'm not using it.....what the heck is going on?? Any help is greatly appreciated!
    Thanks,
    Jeff
  2. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Sounds like you get to replace the heater core! There is a write-up on how to do it and what it involves on the home page I believe. Here is the link <a target="_blank" href=http://coloradok5.com/heatercore.shtml>http://coloradok5.com/heatercore.shtml</a>
    <P ID="edit"><FONT class="small">Edited by 90blzr on 07/17/01 09:48 PM.</FONT></P>
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I concur - it's heater core time - pugsley.alloffroad.com
  4. KING K5
    Sep 28, 2000
    172
    Sacramento, Ca.
    I got out of my rig tonight after work and walked around to the passenger side and there was coolant/water dripping from right in front of my passenger door and I was all.... what the f@#K?!?! so thanks guys, I appreciate the help!
    Happy Wheelin!
    Jeff
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes it is your heater core
    77blazer see it at<a target="_blank" href=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</a>
  6. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Well I would tell you what it is but sence you flaked on Blazer-Fest I ain't gonna...........heheheh JK it is your heater core!
    You did miss out on a good thing!!!
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  7. KING K5
    Sep 28, 2000
    172
    Sacramento, Ca.
    believe me Burt4x4, I really wanted to go but unfortunately had some other stuff that I had to take care of :-(
    Hey, another quick question.....if my heater and A/C are not currently wired up is it safe/ok and is there even a way to bypass the heater core until I can get a chance to replace it?
    it's my daily driver and I wouldn't be able to fix it until probably
    this Sunday.....thanks for the help in determining the problem and thanks in advance for any advice/ideas about bypassing it.
    Jeff
  8. Burt4x4
    6,854
    I hear ya..Life happens! I was just bustin ya![​IMG]
    I have never done it but I would assume you could take the heater hoses and connect the heater inlet to the heater out let so that the fluid doesn't pass thru your core were the leak is.
    Again I have never done this so just guessing.........
  9. KING K5
    Sep 28, 2000
    172
    Sacramento, Ca.
    I was thinking the same thing Steve.....I'll give it a shot and see what happens!! :-)
    Jeff
  10. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    You can safely by-pass the heater core...its pretty self explanatory and will buy you some time til you can replace the core itself.
    Rene
  11. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    yep have two of my trucks bypassed until the winter...pretty simple just look at it and make sure water is still making a complete flow through the manifold and radiator
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
    1982 Chevy C-10 Longbed
