Need Help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 73 K5 Blazer, Mar 21, 2002.
  1. 73 K5 Blazer
    73 K5 Blazer 1/2 ton status
    Sep 14, 2001
    483
    Madison, MS
    I have a friend that has a forerunner that is having starting problems. It starts fine when cold but after it has warmed up it will not start. The battery and starter are new. It will Jump start. Battery is reading 12.3 right now and drops to 11.3 when trying to start. I know this is a little of topic but I know someone can help me out.
  2. smack
    smack 1/2 ton status
    Feb 24, 2000
    277
    Colorado
    What exactly do you mean it will not start?
    Will the engine crank?
  3. 73 K5 Blazer
    Sep 14, 2001
    483
    Madison, MS
    The engine will not turn over. Ther is a click comming form under the dash and under the fule injection.
  4. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    Have him check the timing, this will happen sometimes if it is too high.
  5. smack
    Feb 24, 2000
    277
    Colorado
    Well my guess is that you have a starter solenoid that's overheating -- a common problem on chevy's. Solenoids are very sensitive to heat and since they're located at the bottom of the engine, the exhuast manifold heat frys them frequently. The clicking is likely the ignition coil or possibly the injectors? When I had this problem I replaced my solenoid and installed a heat shield around it. Haven't had the problem since.
  6. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    It could also be a bunch of bad connections. Check all the major wire (0-4 size wire) from battery to solenoid to starter motor.
    Good luck.
