Need HELP!!!!
Discussion in 'Communication (CB | GPS | HAM)' started by MudFrog, Jul 28, 2000.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    My Amp (200 watts) interferes with my CB. I can listen fine, but when I try to talk, this loud obnoxious noise is submitted through my 6x9's running off of my Amp. I tried turning off the stereo (even though the amp was still on). And this did not help it any. My CB is mounted on the front of my console, and my Amp is mounted under my passenger seat. So I know they are close together, and yes they are comming from the same power source(I have one of those Rockford Fosgate power things, single IN, 4 OUT). I do have my CB Antenna Cable sitting on top of the amp, but I didn't think this would make a difference. Ya'll have any ideas?
    89 K5 Silverado
    http://mudfrog.coloradok5.com
  2. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    move the antenna cabel and see if it changes things
    I understand the jeep thing I drive a BLAZER!!
    Ken
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    Also, use a seperate power oputlet for you power wire, this may help.
    Mike [​IMG]
    1982 GMC Jimmy - <font color=green>Emmett</font color=green>
    http://emmett.coloradok5.com
  4. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    This is a common problem. In most cases it's the cb its self usually a good one. The best chance you have is to get your fm antenna and your cb antenna far apart as possible it has nothing to do with your amplifier, its your cb kickin out to hard. Try turning your "dynamic" down a little bit this should help.
    Professional JEEP EATER, it's a population control thing
  5. are your power lines run down one side of truck and the antenna down the other to separate them ? if you run them togethrer you will have this problem .
    mark359@earthlink.net
