Need help!
Discussion in 'The Garage' started by KILLERK5, Jul 22, 2002.
  1. KILLERK5
    KILLERK5 1/2 ton status
    Oct 19, 2000
    108
    Aurora, Colorado
    I can't get my Blazer started. It's not getting fuel. I checked the fuel pump and the filter and they are both fine. I was told to check the EST controll, the distribution module, and the magnetic pick up coil. I don't know what any of these are. I looked through my Chilton's manual and I can't find anything about them in there either. If you know what and where these things are, you would be helping me alot! Thanks ahead of time!!!!!
  2. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    pull off the fuel line that goes into the TBI unit and see if it squirts out fuel. then, go from there.
    NITRO
  3. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    When you turn the key forward do you here the pump whine?
  4. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    The module and coil are in reference to the distributor. Pull a plug wire, ground it to the block with a screwdriver and have someone start the motor. Check to see if the screw driver throws a spark (leave a small gap between the blade and the block). If not, it is an electrical problem. If it does spark you have a fuel delivery problem
  5. Storm Trooper
    Nov 24, 2000
    4,640
    Just remember, TBI needs 45 psi or it won't work. A running pump doesn't mean it has pressure. good luck and let us know what you find.
  6. bklynlifted
    bklynlifted 1/2 ton status
    Feb 4, 2002
    261
    brooklyn ny home of the brave
    WHEN I TURN MY KEY TO THE ON POSITION I DON'T HEAR MY FUEL PUMP?IT TAKES ABOUT 4 SECONEDS FOR MY TRUCK TO START? WHAT'S UP WITH THAT? /forums/images/icons/confused.gif
  7. KILLERK5
    Oct 19, 2000
    108
    Aurora, Colorado
    The fuel pump is new, I changed it only about 3 months ago. It works, but it could be weak. I haven't ever been able to hear it though, even when it was running. I also have spark from the coil to the distributer, but I haven't had anybody else around to help check from the plugs. Now by battery is dead so I have to find a charger before I can do anything else. Well thanks for your info!! You guys have always come through with everything that I have ever asked! You guys are the S...!!!!
