Need Help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pplblazerdude, Dec 19, 2002.
  1. pplblazerdude
    pplblazerdude 1/2 ton status
    Jul 18, 2002
    242
    Kingsport, Tennessee
    I have a 89 chevy blazer k5 with 3.73 gears stock transsy and transfer case and a add a leaf in the back and when im going between 55 and 65 after it has warmed up it sounds like bearing noice and then the noice goes away if u put the tranny in neautral. I have had the driveshaft balanched and done a 180 flip on it, ive put new u joints and new axel bearings plus new spiders. Could the noice be coming from the transfer case.
    Thanks for help or suggestions,
    Tony
  2. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Is the sound coming from the very rear or in the middle?
  3. pplblazerdude
    Jul 18, 2002
    242
    we had the bearings replaced as we said and we cant really tell where its coming from but we know its not in the front and someone told us it might be the chains are lose in the transfer case. /forums/images/graemlins/k5.gif
  4. VisionxOrb
    VisionxOrb 1/2 ton status
    Oct 10, 2001
    251
    Newbury Park, Ca
    hope this isnt the case but my tranny used to make noises like that and have a noticable vibration at certin speeds before it died on me.
  5. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    presuming an automatic and it has enough fluid...
    Check transfer-case fluids...
