Need help!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by coloradoblazers, Aug 2, 2003.
  1. coloradoblazers
    coloradoblazers 1/2 ton status Premium Member
    Mar 2, 2001
    506
    WY
    I am having problems with my 89 suburban power passenger rear window. I wont go up. I tore it aprart trying to fix it but no luck. When I hit the switch for up, nothing, but when I press it down I hear a click. Drivers switch doesn't work either. Some one know how to fix this, or where I can have it repaired. I need this done asap, I am about to deploy and I don't want it sitting w/ no window up! Anyone have an extra door nearby(south GA/north FLA) that I could buy? Help!
    Thanks Jake /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/k5.gif
  2. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    dang your a ga. boy /forums/images/graemlins/eek.gif just get out the duct tape and the clear plastic /forums/images/graemlins/rotfl.gif
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    jake, work the switch while tapping on the motor with the handle of a screwdriver and see if it decides to work, if it does then you need a motor...if not, try jumping the wires off the switch to see if it will go up...
