need help
Discussion in 'The Garage' started by cjb88jimmy, Dec 10, 2003.
  1. cjb88jimmy
    cjb88jimmy Newbie
    Dec 10, 2003
    plattsburgh ny 20miles from canada
    hi folks newbie here.. i have a 88 jimmy stock everything.last week had ignition module go bad replaced it then it developed for poor performance. rough idle rich exhaust not showing engine light. please help any info would be great.... thanks
  2. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    well if the module was going south then it might have fouled the plugs, check them and you firing order. If that all looks good then doule check all you plugs around the distributor and make sure something is not loose or unplugged. /forums/images/graemlins/thumb.gif
    Oh and welcome to the board
  3. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    everything he said, also make sure you didnt change your timing (yes I know you have no need to even loosen the dizzy to change the module but I have seen people do lots of stupided things)
  4. cjb88jimmy
    cjb88jimmy Newbie
    Dec 10, 2003
    thnks guys will check this mornig
