Need Hydro boost help(more questions)
Discussion in 'The Garage' started by sapper, Oct 4, 2005.
  1. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    The cucv I bought only has a couple more days here and I am pulling the break components off for the k5, so far i have the break pedal steering box, steering pump with pulley, master cyclinder(and everything else from the firewall) to the porportioning valve, is there anything else i need to do the swap? Will the master hydro whatever bolt right up to my firwall or do i need to pull the plate off the cucv firwall? And any advice would be great because once agian I am doing something I have no idea how to do. TIA
  2. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    if you undo the 6 bolts holding it on, the same 6 bolts that hold the vac booster on, then it will bolt right up.
  3. sapper
    Jul 11, 2001
    3,052
    NoVa
  4. sapper
    Jul 11, 2001
    3,052
    NoVa
    Now for some questions, I pulled the steering box but after looking at the two of them they look the same, is that true? And finally I think I have to swap the steering pumps, is that true? and if so how do I do that? Thanks
  5. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    I think they only difference between the boxes is the thread for the fittings and or how they seal. Some of the boxes seal with an oring on the line and some use an inverted flare.
    The pump will have another plug on it for the return on from the second hydro device on it.
    When I did my swap I pulled everything that was attached under the hood. Pump, box, master, and the booster itself.
  6. sapper
    Jul 11, 2001
    3,052
    NoVa
    and the hits keep coming-
    Will the steering pump from a 6.2 be able to be used on a 5.7? And is it just pulling the pulley from the 6.2 pump and installing the pulley from the 5.7 onto the 6.2 pump :dunno:
  7. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    Now that I dont know for sure. How GM is, Im sure they are the same. If not you should beable to get one from a parts house.
  8. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    what are you doing there buddy? DOnt tell me your gonna scrap the 6.2!!!!Keep it for me. ;)
  9. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Paul, I use the pump from the 6.2 but had use and modify the bracket from the 350. On my paw inlaws we just used the pump and bracket from the 350 and use a "t" on the low pressure side.
  10. basing110
    basing110 1/2 ton status
    Aug 4, 2005
    298
    san diego
  11. sapper
    Jul 11, 2001
    3,052
    NoVa
    Dude your in San Diego and they are HEAVY, but no pics the camera died.
  12. basing110
    Aug 4, 2005
    298
    san diego
    yea it would be about 110 bucks for shipping i think .. but jcwhitney want 260 without bushings i think
  13. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    ship them separate. alot cheaper.
