Need Hydro clutch help
Discussion in 'The Garage' started by fordeater, Jul 27, 2005.
  1. fordeater
    fordeater 1/2 ton status Premium Member
    Mar 21, 2004
    1,402
    Missoula, Montana
    I need a part number or need to know where to get the rod that goes from the slave cylinder to the clutch fork. I've searched and cannot find it anywhere. Anybody know where to get it, and maybe a part number?
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    you cant find a PN, because it doesnt exist, the slave pushes directly on the clutch fork.
  3. fordeater
    Mar 21, 2004
    1,402
    Missoula, Montana
    Every picture i have seen of a slave has a rod going from the slave to the clutch fork. So, i guess i don't understand it?!?
  4. rumbly truck
    rumbly truck 1/2 ton status
    Jul 4, 2005
    132
    utah
    i cant see a number on mine. but it is about 4.200" long by about.340" in diameter. the end that goes into the slave cylinder has a ball end ground onto it. The other one has about a 10* angle ground for about .400" long then a ball end ground on it.
  5. dyeager535
    26,980
    GM manual I've got doesn't break it down into anything other than the slave cylinder complete, so I don't know as you'll find just the rod.
  6. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I used a long bolt.
    Cut the head off and round the end to seat into the slave's pistion.
    The other end with the threads is used to secure it to the fork.
    You will have to mess with the length of the bolt but just start long and grind it shorter as needed. Works like a champ!
    Good Luck
    Burt
  7. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    that part comes with a new slave cylinder, as does the boot. (from advance auto anyway)
  8. fordeater
    Mar 21, 2004
    1,402
    Missoula, Montana
    i went to schucks and napa, and neither one of them had the rod with the slave. Went to the stealership and ordered it today for like $13.50
