Need Idea how to get Stainless off lower Body-Aftermarket
Discussion in 'The Garage' started by stano, Nov 25, 2005.
  1. stano
    stano 1/2 ton status
    Jan 24, 2005
    130
    Iowa
    Any body have any ideas on how to get this aftermarket stainless steel sheet off of the rockers of the K5.
    I was going to pull and hope they would give away slowly, but they are on so tight I can not even barely get it started. I do not have to save them.
    Would heat from a torch real easy help??
    I don't know, may have to repaint the lower part..
    Also want to take off the molding all the way around and leave off. I have not tried the molding but think it will come easier than the stainless.
    http://groups.msn.com/Fangk5/shoebox.msnw?action=ShowPhoto&PhotoID=1
    thank you
    stano
    87 K5
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    so thats the stainless tape right? hmm i dont think there is anyway with taking paint off from underneath that stuff. maybe a rasor knife? i duno
  3. stano
    Jan 24, 2005
    130
    Iowa
    It is on tight. I think I might dent some of the body trying...
    stano
    87 K5
  4. HELLBENT DESIGNS
    HELLBENT DESIGNS 1/2 ton status
    Apr 2, 2005
    453
    bozeman mt
    for sure heat! heat gun would work best. hair dryer will help but they suck cause they shut off when they get too hot. maybe careful work with a propane torch could be best if you stay away from good paint. i know the double stick 3m type tape under trim will come off easy ( sort of) with a hair dryer or heat gun :D
  5. stano
    Jan 24, 2005
    130
    Iowa
    First of all I don't like it on there and I think that it may hold water and rust...
    And this is a not rusty truck....
    stano
    87 K5
  6. gman454
    gman454 Registered Member
    Sep 23, 2005
    45
    East Hartford, Connecticut
    get a heat gun and heat up small sections at a time real good should peel right off. you might just have to clean up any left over glue. your local homedepot or auto body supply place will have one. should help with saving the paint to:pimp:
  7. stano
    Jan 24, 2005
    130
    Iowa
    Heat Gun... I have one of those for PVC pipe... Yep that might work. Take my time and don't get in a hurry.. Thanks
    stano
    87 K5
  8. Indyblazer
    Indyblazer Registered Member
    Apr 24, 2005
    35
    Indiana
    Go Slow
    First.... NICE K5 !!!
    Second: If you can determine who the manufacturer of the stainless steel pieces is, find the company's phone number, and give them a call. If anybody knows how to get them off your K5.... it will be the manufacturer.
    If there is some type of "non-hardening" glue that is holding the stainless steel to the body metal, I suggest that you try a Hair Dryer as a heating tool to warm and soften the glue. This method of LOW HEAT, applied slowly, would be the least likely to cause any damage to the paint underneath or warp the body sheet metal. Also a Hair Dryer is not likely to be a fire risk like the open flame of a torch.
    If the glue that is holding the stainless steel to the body has "hardened" or does not "soften" with heat applied, then a chemical "release agent" may be required to loosen the glue.
    Go to a local Automobile Paint and Body Shop and ask them for advice. They may have encountered this problem before. Also, they may have a chemical that won't harm your paint AND disolve the glue.
    One last thing.... my experience has been that you may need to call several Auto Paint Supply Stores before you find an answer. If you don't get an answer try some Auto Body Repair Shops. Good Luck !!!
  9. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    Been there, done that. Use a heat gun, not a hair dryer, as you pull off the pieces. Then use laquer thinner to clean up any left overs. 3M also makes a wheel specifically for removing glue. Its not too abrasive that it scratches the paint, but enough so that it removes the glue.
