Need idea?
Discussion in 'The Garage' started by MTBLAZER89, Apr 20, 2003.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I am in the "cleaning" part of my axle upgrade. What are some easy methods to clean the inside of the axle tubes? I need a bore brush from a battleship or something LOL. Thanks.
    -Brian
  2. denver75k5
    denver75k5 1/2 ton status
    May 15, 2001
    1,017
    Somewhere In The Woods
    I just used brake cleaner and compressed air , seemed to do the trick.
  3. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    I used brake clean and a old t-shirt on the end of a
    long push broom.
  4. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    How about a chimney sweep's broom with the bristles cut down a bit? /forums/images/graemlins/thumb.gif
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I took a peice of 3/4" wide aluminum flat stock, drilled a hole in the end, bent it to 90 degrees then bolted a 1.25" OD fender washer to the hole and used it to scrape all the gunk out of the tube. Worked pretty well. /forums/images/graemlins/thumb.gif</font>
  6. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Cool everyone thanks I was thinkin along the lines of the T-shirt with a broom handle. It's not too dirty just old dirty fluid. Thanks.
    -Brian
