Need ideas for moving a K5 body and frame
Discussion in 'The Garage' started by djohnsn, Sep 5, 2005.
  1. djohnsn
    djohnsn 1/2 ton status
    327
    Plano, Texas
    I have found a K5 body and frame that I am interested in, but there is no point in even looking at it unless I have a way to get it home (probably a 2 hr drive). It is just the body and frame. I need some ideas for getting it loaded on a trailer and unloaded once I get it home (I don't have a spare set of springs, axles, wheels and tires to bolt on for the move). Any suggestions?
  2. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    maybe get some big boys and flop it onto a trailer if bodydamage is no concern
  3. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    If it is on a hard surface use two floor jacks. If it is not use thick plywood and two floor jacks. Jack it up around the front of the door area under the frame, drive the trailer under as far as possible. At that point lower the truck, put one jack under the front of the truck (on the trailer) and the other in back and push (may need a 2x4 from frame rail to frame rail to steady it but it has worked for my in the past.
  4. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Use a cherry picker to lift the front end high enough to get the trailer under it. Once the front is on the trailer lift it with a rolling jack. Then lift the rear of it with the cherry picker and roll that biotch onto the trailer.
