Need Ideas on Homemade Spring Pack Retainers
Discussion in 'The Garage' started by DougK20, Apr 10, 2005.
  1. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    My fiddy-2's are fanning out too much at full droop. I'm worried about axle wrap, breaking main leaf, & pinion angle. Looking for ideas on the quickest & easiest ways to make some retainers for them. I'm thinkin' about some with a bolt through the top. Perhaps some cut & drilled c-channel, or something. Any other ideas? Thanks!
  2. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    limiting straps.
    j
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    piece of strap bent in a U, secure to the overload somehow. Limiting strap is a good choice too.
    Replace one of your leaves with a leaf that has a factory retainer?
  4. DougK20
    Feb 18, 2003
    384
    Boise, ID
    I do plan on running limiting straps as well. However, their ability to help axle-wrap is limited. Gotta keep that new front shaft of mine safe! Thanks for the ideas.
  5. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    Im sure if you took a leaf from your pack to a spring shop they could prolly add one (or two) of those u-shaped clamps too it for you also...
    j
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    all you need to do is clamp the main leaf to the leaf under it to prevent any bending in the leafs.
    just get 2 pieces of steel strap that are about 3" long each, drill 2 hole in the ends, put one on the top leaf and the other under it below the 2nd leaf, then just run some bolts threw there to tighten them together.
