Need ideas on removing knuckels and saving ball joints
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nrose07, May 10, 2002.
  1. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    267
    Salem ,Or
    Doing a gear change on my 10 bolt, swapping in a new center section. I have new Moog ball joints in the older axle I'm replacing and as always having a heck of a time getting them out. Want to save the ball joints and knuckels to use in the new center section. Hit with the 5lbs hammer, start to mushroom the bolt & nut. Moves a 1/4" but dosen't drop out. HELP!!!
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Press them.
  3. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    They can be saved. First off do not tap on the ball joint studs or you will mess them up. All you have to do is find two large hammers. Hold one against one side of the axle casting where the lower stud goes in. Use the other hammer to beat on the opposite side of the casting. Alternate between the upper and lower housing and keep your toes out of the way. You might also try loosening the upper spanner sleeve before starting the tapping, it will take the pressure off the upper balljoint. Hope this helps.
  4. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    I use a pickle fork with a wider tang separation and a somewhat dramatic slope angle to each tang. The separation prevents dust boot destruction, while the slope angle removes the knuckle easily without damging the joints. Just a couple of taps with a 5# and out they come.
    How do I know? I replaced my ball joints on the Burb this past weekend. When the driver side was reassembled, I noticed I forgot the upper dust boot! It was 1AM at the time.../forums/images/icons/smile.gif. These ball joints were new and had never seen a single foot, let alone mile, with no time to set , but I think it would work similarly for your application.
    My $0.02...
  5. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,260
    72
    Humboldt/Pacifica, CA
    I just did my ball joints and in the instructions they said that the nut for the lower joint should not be reused since it is a torque prevailing nut. I would suggest getting a new one when you reinstall. Just my .02 /forums/images/icons/smile.gif
