Need ideas to help remove trans
Discussion in 'The Garage' started by mouse, Nov 25, 2005.
  1. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I've almost completed parting the '89 sub that I bought for the TBI system. I still have the 700R4 to remove, but since the engine is seized, I can't get to the last bolts for the torque converter.
    The engine failed, probably because the PO didn't use enough coolant. Both sides of the block are broken - pushed out and cracked. Many things internally are rusty, like the timing chain, and surfaces.
    So far I've removed the heads (they look good), exhaust manifolds, timing cover. I soaked the pistons in oil over night hoping to free them up, and tried to spin the motor with the harmonic balancer bolt; it would'nt budge. I took the BFH (4 lb mini sledge) and smacked the pistons, hoping break something free, no go. But, I might add that I was impressed by their strength. Not one broke... :bow:
    I think that my last choice is to drop the oil pan and disconnect the connecting rods to get it to spin. I am wondering is there is a thrown rod. Two pistons on the passenger side are almost the same height...They are very close, and towards the bottom.
    Any ideas are appreciated. I am trying to sell the trans locally, but if I can'[t remove it, I'm out the $$$ :doah:
  2. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    leave the converter in place and pull the tranny.or could support the tranny and pull what is left of the engine.
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Yep
  4. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,927
    343
    Fort McMurray, Alberta
    It'll make a mess, but I'd just leave the converter on the flexplate as well
  5. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    Although I'm sure I could pull the trans off if the engie/trans were pulled out, I don't think there is enough room to slide the trans back and clear the spline for the pump. The last thing I want to do is have it hanging there by the spline.
    Has anyone actually tried this?
  6. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    I'd pull motor & tranny all in one piece if the motor is bad too.
