Need info. from someone that has a 1 ton Dana 60 front.
Discussion in 'The Garage' started by Klef72K5, Mar 26, 2002.
  1. Klef72K5
    Klef72K5 1/2 ton status
    Apr 8, 2001
    249
    Columbia City, Indiana
    Hey guys I'm doing some checking and need some information from you guys. I'm looking for a 1 ton Dana 60 front. What I need is the strip tag numbers for the axle. They are bolted onto the coverplate. I would prefer from a unit that has 4:10 gears in it originally. It doesn't matter what you have in it now.
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Sorry but mine does not have a tag on it. Most that you will find probably will not have the tag on them.
  3. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    My tag was gone when I got it.
  4. blazbrnc
    blazbrnc 1/2 ton status
    Mar 16, 2001
    181
    southern MI
    Mine still has it's tag, 4:10's. What info do you need?
  5. Klef72K5
    Apr 8, 2001
    249
    I need all the numbers and letters. Depending on the year it should look like this:
    520C9406.....LS
    4:10........ 589S
    Spacing wouldn't come out right so I added periods
    Just be sure to put spaces in where they are in the tag like the example above.
    Thanks a BUNCH!
  6. blazbrnc
    Mar 16, 2001
    181
    southern MI
    OK give me a day or so and I'll post it.
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    So, you work at Dana? Any good deals? /forums/images/icons/laugh.gif I have the D60 4.56 CUCV axle and the tag is still on it if your interested.
  8. Klef72K5
    Apr 8, 2001
    249
    I've been laid off for 6 months now. Hoping unemployment will buy me a Dana 60!
    What is a CUCV? I was reading about it in another post. They were talking about the hubs being different. Did it come off a dually? If not, send the numbers.
  9. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I have a Dana 60 off of a '85 CUCV. The tag reads as follows: 41-9
    4 56
    That is all that is on the tag. Since you worked at Dana, have you ever seen the fish symbol ever used with a build spec? If so, what does it mean.
  10. Klef72K5
    Apr 8, 2001
    249
    Where is the fish symbol at?
    The 41 is your ring gear tooth count and the 9 is your pinion tooth count. If you divide 9 into 41 you get 4.56 (your gear ratio incase you didn't already know). I wonder if they stamped the chevy axle number on the tubes instead of puting them on the strip tag. Do you know? If they did they are probably 1/8" stamps. If you get some time and it's dry outside could you check?
    What does CUCV mean?
  11. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    CUCV I believe means it came off a military issue truck....
  12. blazbrnc
    Mar 16, 2001
    181
    southern MI
    Here's what my tag says. I don't think it is what you are looking for though.
    41-10
    4.10
  13. Klef72K5
    Apr 8, 2001
    249
    no it's not what I'm looking for. I'm starting to wonder if they were on the axle tube instead. If so I would guess the passenger side under the rust.
  14. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    are you after BOM numbers? they are on the tube
  15. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    Here are the numbers that appear on the tube between the steering stabilizer and the drivers side perch. There is one more set on #'s but the axle is a little muddy right now and a little hard to find.
    6 11 5 8A 610201 1 SJA
    My axles are supposed to have come off of a '85 CUCV which is a 1 ton military truck.
