Need Info on a D60 Crossover.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by californiak5, Jan 11, 2002.
  1. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    Hey there,
    I know alot of you are running the crossover steering on your D60's and I was wondering if I could get a few measurements from you. I need the distance on the passenger side steering arm from the center of the Kingpin (Stock cap where the zirk fitting is) to the center of the tapered (or straight) hole where the draglink connects to it. The other one I need would be the thickness of the steel used for the arm. And if you could tell me were the arm came from (Toy Box, ORD, ORU and such) that would be great and if it has the angle (or twist) on the end of it also. Thanks for any and all help.
    See Ya,
    Keith
    "Your just mad cause the voices only talk to me."
    <a target="_blank" href=http://coloradok5.com/gallery/californiak5>CaliforniaK5's Pictures</a>
  2. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    6 3/4 o/c from the zerk to the center of where the drag link connects
    and its 1 3/4 thick but it has a taper to it where the drag link connects....i dont know what that is tho...mine is a ORD arm
    <font color=green>Chaz</font color=green>
    [​IMG]<a target="_blank" href=http://community.webshots.com/user/chaz88k5>http://community.webshots.com/user/chaz88k5</a>[​IMG]
  3. californiak5
    Oct 25, 2000
    820
    Thanks Chaz. The angle should be around 10 deg. I think. Just for future referance. [​IMG]
    Any one else with different measurements/thickness or made from elsewhere. I am just wondering if they are all the same or if some companies have different opinions on the arms. Thanks in advance.
    See Ya,
    Keith
  4. californiak5
    Oct 25, 2000
    820
    So.....Chaz is the only one with this info, or is everyone else that has it afraid to share it? [​IMG]
    Just bringing it back to the top for one more try.
    See Ya,
    Keith
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    hopefully everyone makes them to match the available pitman arms
    formerly 77chev
    still a jerk though
  6. californiak5
    Oct 25, 2000
    820
    Thanks for the great insite. I don't know what I would do without ya.
    See Ya,
    Keith
