<<<<<<Need Info on IFS and TTB and Why They Suck>>>>>>
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerGuy, Jan 10, 2001.
  1. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Ok, I need info on why IFS and Ford TTB aren't the greatest setup for off-road compared to a solid axle. I got some guys telling me that they're IFS(and TTB) is better, but I know it's not yet I dont know why! Thanks
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Re: <<<<Need Info on IFS and TTB>>>>>>
    With TTB, front tires wear out after 15K, and the axle can't articulate over rocks with either one. Tell them how hard it is to lift the TTB and IFS, and how easy it is for a Blazer with a solid axle.
    90K5
  3. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Oh yeah, I didn't think about lift cost. [​IMG][​IMG][​IMG]
  4. Phaeton
    Phaeton Registered Member
    Jan 6, 2001
    12
    Tell tham that even though the IFS CV joints are way stronger and last longer than U-joints. They cost an arm and a leg to replace.
  5. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Articulation is limited. Cost of lifting is way more. You can't lift IFS more than 6 inches where as you can buy 12+ inch springs for a solid axle. They are no where as strong as solid axles can be.
    '73 K5
    Chevy good...Ford bad
  6. lukers
    lukers Registered Member
    Aug 12, 2000
    64
    Massachusetts
    What does TTB stand for?
    Luke
  7. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Can't remember...something like "twin..xxxx...xxx" Anyway, they are notorious for handling problems after being lifted. The design is basically a solid front axle that has a joint about in the middle. This causes the tires to get really weird cast/camber/etc. angles when it's lifted. IFS can be awsome if it's designed with the lift in mind and uses springs and not torsion bars. You run into similar problems when lifting IFS as you do when lifting short wheel base vehicles to extreme heights. think of the front diff in an IFS as the transfer case in a short wheelbase veh. You start getting extreme angles on your u-joints (CV joints) which is bad. I don't think they make any lockers for the 1 ton IFSs either, and very few lockers for the 1/2 ton IFSs. In my opinion, TTB is old technology that never really worked well anyway. IFS is good, recent technology that is difficult to push beyond it's design specs. Solid axles are good, old technology that can be easily and well adapted to new applications...ie tall lifts.
  8. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,077
    486
    Grand Rapids area
    TTB : Twin Traction Beam
    <font color=blue>Powered by a Goodwrench 4-bolt longblock [​IMG]
    240hp...for now.</font color=blue>
  9. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    I know this is the least technical reason you will ever hear, but....
    Tell them to look into any 4wd magazine at the lift kits. The IFS kits have about 10x as many pieces as the leaf spring (straight axle) kits. They are some pretty small pieces too!
    That says complicated to me. And the more parts you have/change, the more can break.
    <font color=blue>"You call it clearance, I call it head room." [​IMG]</font color=blue>
  10. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Watch an IFS 4x4 truck that has been lifted and has 33" or so tires on it drive down the road...when it hits a bump the front tires are jiggling all over the place, moving in planes that they were not intended to move!!! Its actually funny to watch, they look so damned weak-a*sed that its hilarious!!! Also, watch and old Ford TTB Bronco or truck drive down the road and watch when the suspension cycles like on a bump the tire move in arcs that look like the front tires are gonna fold under the truck and roll the truck!! Also really funny to watch!!!
    ken
  11. Josh
    Josh Registered Member
    Dec 11, 2000
    75
    Glendale, AZ
    They also suck because the more the suspension compresses the lower the diff gets. (better have skid plates)
    Josh
  12. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    The Twin Traction Beam was loosely based on the 2wd Twin-I beam which sucked,too. They both produced wide changes in track width while cycling thru their travel..and were infamous for crappy steering feel and eating tires. Lift one even as little as 4 inches and you've just bought major league steering correction problems. Even the late 70's STRAIGHT axle-coil spring-radius arm susp. took degree bushings and steering tricks to lift right. Ford just ran 1980 technology for 20 years to make profits.
    "I'm not stuck...I'm just exploring the depth and texture of this mudhole for a while"
  13. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I know a guy with a Bronco II (TTB front end) with 38's. Not sure of the exact lift. The thing is awesome off road, and he really pummels on the axles with his right foot.
    I haven't driven it, but I've been in it (passenger) off road and it rocks. But a solid axle is still a better design without question.
    -- Mike
