Need Info on Smittybilt Rollbars...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerGuy, Feb 21, 2001.
  1. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I want to get a rollbar and was wondering if the Smittybilt one will actually hold up during a rollover or if it's just dead weight. I probably wont be doing any end-over-end rolls either. The specs on it are 2" x .120 wall steel tubing, is that good enough??? I assume it hold up better if I used sandwich plates or even fabbed up some type of bracket to connect it to the frame. Also, do any of you have pics of one installed and are there any other brands besides Smittybilt that I could consider. Thanks
    Murphy's Laws on Life :
    "Leftover nuts never match leftover bolts." [​IMG]
  2. elkboy
    elkboy 1/2 ton status
    Aug 18, 2000
    293
    Hillsboro Oregon
    I bought the smittybilt rollbar and cage kit through 4wheel wholesellers. It's the only complete aftermarket kit I have found. I'm pretty sure it's heavy enough for a 10 MPH roll if you install it properly, although I have not personally tested one out [​IMG]. It comes with washers to bolt it to the tub which need to be replaced with steel plates at a minimum. To do it really right you will need to connect it to the frame with 2" tube, but you will lose all your body flex. I betting if your tub is not rusted it will hold up to your average trail roll without connecting it to the frame. If I was planning any high speed action I would have a cage built.
    Worthless advice only $.02
    [​IMG]<font color=red> Elkboy</font color=red> [​IMG]
