need info quick!
Discussion in 'The Garage' started by lifted95z71, Apr 30, 2003.
  1. lifted95z71
    lifted95z71 1/2 ton status
    Nov 19, 2001
    248
    birmingham alabama
    ok i have a 95 z71 that im doing a solid axle conversion on. the front is all finished up but im stuck on the rear. the rear im using is a dana 60 out of a dodge van and everything is all set up but i cant figure out what to do about the ujoint. the stock chevy u joint is too narrow for the 1410(?) yoke on the 60. i cant afford to buy a new driveshaft so i was wondering about a conversion joint. a friend of mine with a ramcharger used a ram charger t-case u joint that was longer one way than the other. so one part fit her dana 60 and one part fit ther stock dodge driveshaft. is there anything like that that i can do for chevys? my u joint now fits a 10 bolt. im sure some of you have replaced a 10 bolt with a dana 60 so what joint did you use. remember i cant afford too much. thanks
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Go to Napa and get joint #447. That's a 1330-1350 combo joint. Run you maybe about $20-25.
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    [/ QUOTE ] if that don't work then you will need a chevy dana 60 yoke /forums/images/graemlins/thumb.gif
