Need Input!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, May 19, 2000.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Ok guys/gals,
    This is relating to my previous post about the np203 in the 79 blazer.
    Well now I need to know what ya'll think of the 79 blazer in general. Any thing I should especially keep an eye out for?
    Does the frame still crack at the steering box like in the mid 80's models?
    This blazer does have the part time conversion kit, does anyone else out there have this? Does it work good? And last but not least, I have a HECK of a time getting these doors to shut, I grabbed the bottom of the door and pulled up there was some play, about 1/2 an inch to 1 inches or so, the question is, with this amount of play, if I replaced the door hinges would that be enough to correct the problem or does it sound like I would need new body bushings also? And correct me if I'm wrong (only done 1 body lift, on a toyota) if I add a body lift I won't need to replace the body bushings. Or will I need new body bushings also if I decide to just add a body lift? Oh yea.... 4" suspension, 3" body, would 38" 14.50/15.50's rub the fenders(15x10 wheels). Well I think I'll stop asking questions for now. Thanks for the help.
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Hey MudFrog
    I don't know anything about the 79 but on my 72 I have 4"supen w/3" body and when you do the bodylift I would recomend a body mount bushing kit made by http://www.energysuspension.com and get the black kit it is said to be inpregnated with polygraphite to reduce the poly squeek syndrom!!
    As for your 38"ers I would say yes they will fit but also would hit the corners when on a flexy trail, but a hammer or trimming will fix that[​IMG]!!
    Late
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    If you install a body lift and io not reinstall the bushings then you are not really getting the total lift.. You really should install new bushings!
    Mike
    82 GMC Jimmy "Emmett"
    IN TOO DEEP Off-Road Club
  4. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    To answer your steering box frame cracking, Yeah, they are prone. I think all blazers are prone to frame cracking. I'm not 100% about 69-72 K5's, but definate on 73-91 K5's.
    Boss
  5. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Thanks guys,
    Well the way I see it is if I gotta put new bushings on, I might as well get some extra lift from a body lift.
  6. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I'm not a fan of big body lifts. If I was going to run 38's, I'd get a 6 inch lift and cut the fenders. And you do NEED to do the frame brace before you do anything else. www.offroaddesign.com has one for $100. It was cake to install. I had a '79 Blazer in high school and I loved it. Have fun
    '73 K5
    Chevy good...Ford bad
  7. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Well I reckon if I was to do a 6" lift I could add some cut out fender flares, it should clear ok with that.
