Need locker help
Discussion in 'The Garage' started by odoa3, Nov 10, 2005.
  1. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    I am trying to decide what locker to put in the front of the K5. I am swapping in a Dana 60 next spring, and rebuilding it this winter. I am concerned with loosing my turning radius, the little bit I do have with a full spool in the rear. I will have crossover steering to help with the turning as well. I run in mostly mud and trails with a few rock piles here and there. I would like to put a regular Detroit locker in it. Will I be sorry?
    Also, anyone know anything about the Detroit NoSpin? Good, bad, unknown? It seems like it would have a little more give to it for the turning. I just can't find much information about it.
    Thanks for any help or info.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    The No-Spin is a Detroit Locker.
    I have one in my D60 and the turning radius does suck in the long bed, but i deal with it. If i had crossover i am sure it would help.
  3. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Crossover or with Hydro assist will help. You can always unlock one hub for easier turning when need be. I would just Detroit it since I couldnt afford to go with an ARB or the likes.
  4. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    Readymix- With the NoSpin have you ever felt like you needed the original Detroit locker? Does it lock up pretty solid, so both front tires are pulling 100%, or do you feel one tire give up? I liked the idea of some give for turning, but I really wanted it to lock up hard when i was on the gas. Can you give me some real life experiences with it, both good and bad?
    Thanks, much appreciated.
  5. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    go detroit. I have one in my 60, no regrets at all. Turning radius is increased... but i have hydro assist and if I really want/need to crank it, I can. Usually I just make multiple-point turns so I'm not needlessly overworking the steering system etc though.
    j
  6. trailblazr81
    May 27, 2005
    931
    Hollister, CA
  7. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The NoSpin and Detroit Locker work the same way, just different packaging for different applications.................technically the NoSpin is the drop-in style that just replaces the spider and side gears in a two piece case commonly found in 14-bolts, Rockwells, and other big truck pieces. The Detroit Locker is a full case replacement made for light truck and car applications that have a one piece carrier (Dana 60's, 10-bolts, etc....).
    I've ran many trails with several different people with both open front diffs, selectables like ARBs, and full-time lockers. Watching them from outside the vehicle in tight turns on the trail it's really hard to tell which is which. It's not like the full-time locker guys are having a noticably tougher time making a sharp turn around a tree. I've personally ran a limited slip front and a full-locker in the front and noticed very little difference with turning ability. There has never been a time where I said "gee, I wish I had a selectable locker so I could unlock it for this turn". Out of the several guys I run with on a regular basis all of them have that same opinion.
  8. readymix
    May 30, 2004
    6,706
    26
    As stated above the No-Spin and the Detroit Locker are one and the same. I love having it in my truck front and rear axles. It can make turning in the tight trails a PITA but it is worth it. Having one in the rear is not so bad. My truck has a SM465 so it acts more like a spool around corners.
  9. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    Thanks guys! :waytogo: Never had a front locker before so want to be fully informed. The regular Detroit is the way I really want to go for reliability so this is reasuring.
  10. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If you want to offroad the truck hard there in no replacement for a full locker in the front. The turning isn't great but you will get used to it. Crossover makes it better and hydro makes it even better then that. For a D60 and reliability I would only choose the Detroit locker. It is tried and true in thousands of rigs with minimal failures.
    Harley
  11. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    how is that?
  12. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Been running with a locker in the front of my K5 for a long time. Locked in rear too. Dont have a D60. Just running 10 bolts. But. I have no problems.Usually run with 1 hub unlocked til i need it to avoid unneeded wear and tear on my poor o'l 10 bolts. Detroit IMHO is the best.
  13. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    I think I understand what he is saying with this. I have the 465 as well and I don't know that it makes it act more like a spool but without a torque converter to soften the input to the axles you will notice it kicking in and out a lot more than with an auto tranny. The lockers engage with torque being applied to them and it is quite a bit more obvious with the manual than any of the auto tranny trucks i've driven. Almost unfriendly on the street as opposed to not even knowing its there.
  14. gotmud77
    gotmud77 1/2 ton status
    Aug 4, 2003
    689
    bellefonte
    I would recommend a selectable locker of some sort. Ox,ARB, something like that. I am going to run one of the ox lockers in mine. I dont want to deal with the on road problems with a front detroit and i dont want to get out and unlock one hub just to turn easyer on the trail. I like the fact that i can lock and unlock the ox and they seem plenty stout enough. The only bad thing i see is the cost of the ox over a detroit.
  15. readymix
    May 30, 2004
    6,706
    26
    Exactly. Along the same note.....it does not bother me though. The cops on the base here gove me dirty looks though when i turn a corner. :haha:
  16. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    :D Yeah you get used to it. At least its always there reminding you to go offroading by chirping and banging at you lol
  17. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Go Detroit and you'll understand.... It's "THE" best.Period.:D
