need locker info!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigredblazer, Jul 2, 2001.
  1. bigredblazer
    bigredblazer 1/2 ton status
    May 10, 2001
    170
    western slope
    I'm planning on installing a Detroit locker soon, has anyone had handling problems with them? Does anyone know if someone makes a spool for a 14 bolt? Thanks for any info! Jon
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Check out the current issue of 4 Wheel & Off-road. There is an infomative article on these in it
    Murphy's Laws on Life:
    "A bird in the hand is worth three Kleenex."
    <A target="_blank" HREF=http://www.K5.rockcrawler.com>http://www.K5.rockcrawler.com</A> *under construction*
  3. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I recently got a Detroit.I had worries of tire wear ,banging,and ratcheting sounds around corners but I wanted 100% lock up off road.It doesnt matter if one of the rear tires is off the ground both will still get power.If you are easy on the gas or coast around a corner you never know its there.Gas it durring a turn and it will chirp the tires.Now that I have one I would never have anything else.
    <A target="_blank" HREF=http://community.webshots.com/user/beaterwhang>http://community.webshots.com/user/beaterwhang</A>
  4. bigredblazer
    May 10, 2001
    170
    western slope
    thanks for the feedback ! I'm pretty sure no one makes a spool for theese rearends, but it doesn't hurt to ask. I guess the Detroit is like any other mod you do, you just have to adjust. Thanks again. Jon
  5. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    I saw a post somewhere a while back stating that Cone Industries is making a spool for a 14 bolt. http://www.coneindustries.com/
    All they have listed is for 40 Spline axles. I do not know if Moser, Dutchman, etc... could produce 40's for them, but they must be getting them somewhere. Did not mention price either. I just figured if I really wanted to be Locked all the time, I would fire up the Hobart to my POS Gov-loc carrier. Too bad Detroit did not make a retrofit for the Gov-Loc. Since the Gov is so easy to toast.
  6. rodzzilla
    953
    Grinnell, IA
    Ooopppssssssssssss. Just looked at the site again, and they make them for 46 spline, not 40.
  7. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    It takes about 5 min to get used to it. That would be 5 min of each type of driving-city, mud, rocks, hiway, ect. No worries, you will love it. At least I do.
    Jim '80 GMC
    Freedom First!
    <A target="_blank" HREF=http://www.bigjbear.coloradok5.com>http://www.bigjbear.coloradok5.com</A>
