need longer studs.
Discussion in 'The Garage' started by Jonny-K5, Feb 4, 2004.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    my stock wheel studs are too short for my alloy wheels, i only get 4 or 5 threads on. went to the auto parts store and they dont have the right knurl size. my truck has 7/16 20 1 1/4 4.80 knurl studs. they only have .460 or .560. will the .460 work? should i drill them out to accept the .560? is there some place on the web where i can get the right ones? i need 2" studs, stock is 1 1/4.
  2. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    talked to napa and they have studs that are .475, not .480. is that close enough or are they gonna spin.
  3. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    I though some wheel require special lug nuts?? /forums/images/graemlins/ears.gif
  4. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    ya they take acorn nuts, but they are also thicker. hasent anyone had this problem?
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Never had issues, although never had alloy wheels on my Chevy. 3/4 and 1 ton axles have super long studs though, so probably not an issue. /forums/images/graemlins/thumb.gif
    Check Summit or Jegs. The racecar guys often need longer studs.
  6. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    good idea, thanks.
  7. homerman5409
    homerman5409 Registered Member
    Dec 12, 2003
    7
    I had the same problem. I have Eagle 589 rims and the studs in the front werent long enough. I got Moroso #46220 studs (Jegs). I have them in, but still in question. A few wanted to twist when being installed. But so far they are holding up. I might go to NAPA and see if the ones someone mentioned might be better.
