Need longer than stock 9/16 wheel studs!
Discussion in 'The Garage' started by dieselandmud, Aug 3, 2006.
  1. dieselandmud
    dieselandmud Registered Member
    Aug 30, 2004
    17
    Cookeville, TN
    I've done the 8-lug conversion on my 86' K-10 10 bolt front axle and the stock 9/16-18 wheel studs are too short for my aluminum wheels. Does anyone have a good source for wheel studs? The local Truck Pro store has had some on back order for over 2 months and no delivery date in site.
    I need
    Euclid part # E-8959-R, .625" knurl dia., ***length 2 13/16".
    Most other studs I've found are only 2 1/8" in length.
    I need 16 of them.
    Chris
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    check with any local tire/wheel store/installer
  3. dieselandmud
    Aug 30, 2004
    17
    Cookeville, TN
    I've checked with all the local places and a few on the internet. They all have them but they are all too short.
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Get some dually lugs
  5. dieselandmud
    Aug 30, 2004
    17
    Cookeville, TN
    Is a dana 60 front wheel stud the same as a 10 bolt front axle wheel stud?
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I can't answer that as I don't have either, I've got a 44
  7. AKbigsub
    AKbigsub 1/2 ton status Premium Member
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    I just did a disc conversion on a 14bff and had to go with dually studs. NAPA part # BK641-1066. I don't know if that's what you need, but they worked great for my application.
  8. AKbigsub
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    I just measured my studs and they are 3 5/8" (just the length of the shaft) and 3 15/16" (length of the entire thing).
  9. dieselandmud
    Aug 30, 2004
    17
    Cookeville, TN
    Thanks for the reply AKbigsub. I went to NAPA to check but it won't work. The wheel studs need a .625" knurl dia. and then another step up. I guess the brake rotor has a slightly larger hole than the hub. However NAPA did have a wheel stud with .628" knurl dia. with the correct length. Does anyone know if that would press in OK and work?
  10. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    what wheels are you running? can you post a pic. i work with wheels and tires all day at work. never realy found this problem.
  11. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    I've got the same problem. I'm running M/T Classic II and have about 4 threads worth of engagement. Have the 1 ton running gear too.
  12. dieselandmud
    Aug 30, 2004
    17
    Cookeville, TN
    I'm running some cheap made in China ProComp wheels. I think the part number is 1069. I will try post some pics. I'm using an open end wheel nut and you can see about one and a half threads into the nut!
  13. sweetk30
    Nov 1, 2004
    25,539
    538
    funny i have mt II on my truck with 60 and 14ff with no problems. sorry i cant help further .:confused:
