need lug nuts?
Discussion in 'The Garage' started by Pow06er, Jun 1, 2005.
  1. Pow06er
    Pow06er 1/2 ton status
    Apr 9, 2005
    188
    ne, ohio
    I need some lugnuts for my k5 6-lug 10bolt
    Autozone doesnt have enough
    and the ones they had were too short
    Where should i go and look and wat exact size do i need?
  2. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    get the acorn style nuts... they work and can't be "to short".
    j
  3. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    summit sells just about every style lug nut you could want
    www.summitracing.com
    or just go to a junkyard and look around, you can easily find some that will paint up nicely for $0.25 ea or so
  4. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    they usually take alot of the wheels off trucks at p+p's around here, but if you look in the beds of the pickups there are usually lug nuts scattered around. You can usually fit a handleful or two into your pockets also :) which is a lot better than paying autozone 5 bucks or so for a couple lug nuts... if you're not sure if they're the right size, just find a similar truck to yours and screw em on and see if they fit...
  5. Pow06er
    Apr 9, 2005
    188
    ne, ohio
    i wanted new ones so i went out and bought some
  6. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    trust me get em from discount tires!
    mike
  7. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    How many more do you need?
    Most parts stores have them but the wingnuts at the counter usually can't find them.
    I've got a bunch in my nut bucket :grin: I'll send you as many as you need for the price of postage.
    :D
  8. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Unless he has mag wheels........
    Take one of your wheels and/or one of the nuts you have to a local tire shop that way they can make sure you get the nut the right size and seat. If you are running aluminum wheels and you get a nut with the wrong seat it can snap the stud and damage the wheel. If you have steel wheels you can put almost anything on and be OK. :D
  9. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    surely autozone isn't the only parts store around ?
    I've had to go to 2 differant stores before to get enough lug nuts to go all the way around.
