Need massive help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chevykid350, May 6, 2003.
  1. Chevykid350
    Chevykid350 Registered Member
    Apr 2, 2002
    13
    Elizabeth, Co
    Can anybody help? My father and I are swapping a LT1 from a 96' Impala SS into his 90 Suburban where can I get a wire harness and computer from? Is there any other thing we need to be aware of for this swap?
    Thanks for any help
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Painless Wiring makes a complete wiring harness for swapping the LT-1's. They should have one for your application.
  3. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Try searching the forums, this was addressed about 2 weeks ago. /forums/images/graemlins/thumb.gif
  4. dyeager535
    26,982
    191
    Stay the hell away from Painless.
    A *lot* of aftermarket harnesses will put your setup in "limp home" mode, or disable features that make modern engines so fun to drive, so you are going to want a "stock functioning" harness. No EGR delete, no VSS delete, no park/neutral grounding, and so on.
  5. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    junk yard maybe /forums/images/graemlins/thumb.gif
  6. BlaznRebel
    BlaznRebel 1/2 ton status
    Sep 1, 2002
    115
    Louisiana,Baton Rouge
    be very aware that you may have to cut the frame to get the AC pump in. Either that or you will have to get a set of brackets off of a corvette so that the AC pump is moved to the top left instead of the bottom right. Just put on in a 91 GMC will get pics if you want to see how we did it. /forums/images/graemlins/deal.gif
