Need measurements of 4" lift fr spring
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Liberator, Jul 1, 2002.
  1. Liberator
    Liberator 1/2 ton status
    Jul 16, 2001
    276
    Communist California
    Need measurements of 4\" lift fr spring
    My 4" front springs are sagging and have been for a long time now! Since my K-5 will be running soon I like to fix it's ground-gazing problem. Jeff Deaver at Deaver Spring in Santa Ana CA can fix the problem. However, I need to know how much they're sagging. The rear springs have an add-a-leaf and have always sat a little higher than the front so I can't just level the truck. I need the distance between the top of the u-bolt plate or axle tube to the frame, stock bump stop or some other reference point. Whatever measurement is easier for you! Any spring other than Tuff Country Easy Rides is fine. I have EZ rides right now and don't want Tuff Country measurements because of my loss of faith in them.
    Any help is greatly appreciated!
    Bo
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Re: Need measurements of 4\" lift fr spring
    Top of the U-bolt plate to the top edge of the bumpstop bracket...drivers side 8.5", Passenger side 8.25". Rancho extra stiff 4" springs. /forums/images/icons/grin.gif
    Hopefully that gets you started...
    Rene
  3. Liberator
    Jul 16, 2001
    276
    Thanks for the help! I'll measure mine as soon as I get home from work. I may just have my rear end too high with those add-a-leafs! If that's the case I'll have Deaver Spring make a custom set of springs.
    Thanks again.
    Bo
  4. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    Perhaps you could jack the front of the truck up from the frame or bumper until it is level or the desired height is achieved, and then take the measurements that you need. It should work unless your springs are so stiff that it picks up the axle off the ground.
  5. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I'm not sure the top of the u-bolt plate would be a good measuring point as different front lift kits have a different number of leaves and the measurement could be as much as an inch off. Different axles and their different perch heights could make for an erronious reading too if measured from the axle.
    I too have the Rancho stiff as a brick but not the HD front springs but on a Dana 60. The axle swap alone gave me 1/2 - 3/4 of an inch. Anyone ever yank a leaf from these packs to soften them up?
  6. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I'll have to go out and measure off the axle tube then. I think I'm going to try mixing and matching some of my old leafs from my rear 52" pack with one or two from the Rancho 4" pack. See if I can't come up with something a little nicer riding and flexier. I'll definitely use the 52" main leaf and move the front mount forwards...
    Rene
  7. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    Their was a thread a couple of months ago on this. I think it was in ORD's section. On average ride heights, being measured from top of axle tube to the bottom of the bump stop bracket. I think 10.5" to 12.5" was average measurements for a 4" lift. Mine is 12". Hopefully this will help.
    Later Ed
