Need more flex.....any ideas?
Discussion in 'The Garage' started by kmodi, Dec 8, 2005.
  1. kmodi
    kmodi Registered Member
    Nov 9, 2005
    56
    Atlanta GA
    I have a CUCV k30 with 10" superlift springs in the front, 6" springs in the rear with the ORD shackle flip running and 46" michelins. What can I do to get more flex?
  2. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    softer springs such as alcans, better shackle angle with longer shackles...besides that, not much else you can do with springs that tall...
  3. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    I'm afraid there's not much you can do up front with 10" springs. Maybe 8" BDS, 1" zero-rate and 1" body lift could give you the same height with a much better ride. The flip in the back is a good place to start, but I would run 4" springs (bds, tuff country), zero rate and again the body lift with that shackle flip. I've always loved that truck you've got. If you could get it to flex well with those tires it would be badass!
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    shackles and softer springs are the options I see. not that I can even see your shackle angle.
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    put 6" lift 52's up front, 6" shackle flip + 4" lift 56's in the rear
  6. kmodi
    Nov 9, 2005
    56
    Atlanta GA
    who makes a 6"flip? i definately think i need to lower it and just cut the hell out of the fenders, who makes the best springs? if i put 6's or 4's instead of the 10's would it change the pioion angle enough that i would have to get driveshafts again? also what is a good template for cutting the fenders?
  7. SUPER'BURB
    SUPER'BURB 1/2 ton status
    Jan 9, 2005
    929
    Mountain House, Ca.
    That rig is BURRRRRLY:eek1:.
    4 link:rolleyes: sorry couldn't help it.
  8. kmodi
    Nov 9, 2005
    56
    Atlanta GA
    i know i know! 4 link is the way to go but i am not ready to put it in the garage for a few months yet:D anybody have experience with national spring?
  9. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    I have some friends that run national springs and they said the quality has gone down. I was told it was because they started using cheaper metal but tried to compinsate by adding a extra leaf. Personally I would recommend Deaver Springs, I have them on my blazer and love them.
  10. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    alcans and deavers are both really good, you cant go wrong with a custom spring, but these are the only 2 brands that i have ever heard of that no one has complaints with:D
  11. kmodi
    Nov 9, 2005
    56
    Atlanta GA
    bump
  12. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Got any other pics?:D
  13. koldsimer
    Jan 10, 2005
    1,480
    texas
    From what I have heard Deaver, Alcan, Atlas and National are all reputable spring makers but they are pricey. From what I know by personal experience, BDS and Tuff Country springs are excellent, affordable choices. They flex like mad, ride great, are durable and have great warranty. If you have a BDS dealer near you, I would just get my springs from them. They have the best warranty in the business. You break it, they replace it. I can't remember the last time I lifted a front tire with my 6" front springs.
  14. kmodi
    Nov 9, 2005
    56
    Atlanta GA
    here are a few more pics
  15. kmodi
    Nov 9, 2005
    56
    Atlanta GA
    right now it has ORD highsteer, ORD flips, 4.56's detroit in the rear.
    I am putting chromo 35 spline and a detroit in the front next week. I am ordering ctm's all the way around. Looking for some beadlocks. ORD bumper is in the mail.
  16. SUPER'BURB
    Jan 9, 2005
    929
    Mountain House, Ca.
    Do a search for trimming I have seen alot of good looking trim jobs on CK5.:hack: :xmas:
  17. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    yeah. looks to me like you need to lower the amount of lift you have and trim those fenders a bunch. Going to something like 6" springs up front and 2-3" springs in the rear (plus 'da flip) would prolly help a lot. I'd recommend BDS. Switching to 56s or 63s in the rear... and 52s or 56s in front would help a lot too...
    j
  18. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    I would think that to keep it on the cheap and make some improvements for the time being, You could probably just pull a couple leafs all the way around, check you shackle angles and move the shackle mounts to adjust accordingly. Then Just trim to fit. Probably make a big difference and not break the bank when you may not need too. You wont be able to take full advantage of the flex of 52's up front with those tires unless you virtually remove your fenders.
  19. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Too bad I didn't have a 102" projection monitor so I could see those pics.
  20. kmodi
    Nov 9, 2005
    56
    Atlanta GA
    a fender hacking is definately in the works for this weekend, any opinions on weather to follow the factor fender shape or to go with something more circular. Also what angle is most preferred for schackles?
