Need new distributor...what's best?
Discussion in 'The Garage' started by jdoe, Jan 18, 2004.
  1. jdoe
    jdoe Registered Member
    Jan 4, 2004
    6
    Need new distributor...what\'s best?
    Does any particular parts maker stand out as being the best maker of distributors/ignition system parts, or are all aftermarket parts pretty much the same? /forums/images/graemlins/ears.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    Re: Need new distributor...what\'s best?
    MSD is kick ass stuff, so is Mallory..
    try filling out your profile so we know exactly what you're working on.. makes direct suggestions easier.. /forums/images/graemlins/thumb.gif /forums/images/graemlins/truck.gif
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    This isn't a bad deal if you have a good HEI distributor and want a upgrade. [​IMG] [​IMG]
  4. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    I'd watch the MSD...I just replaced my Billet dist that was 1 yr old and had 7k miles on it. After I couldnt figure it out I had it to 2 shops and all they could come up with was a bad distributor So they replaced the ignition with stock. Figured my engine is stock so why drop all the cash(again) on something I didn't need.
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
  6. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    I just ordered one through Jeg's for $159.99!
    Proform High Performance HEI Distributor
    100% New Parts!
    These high performance HEI distributor produces a 50,000 volt spark through 7500 rpm, offers true spark alignment for instantaneous voltage response, a high performance advance curve, plus a high performance coil and cap with brass terminals. Also includes a low-saturation ignition module for maximum spark intensity and high output coil.
    Bill
  7. Stroked72Blazer
    Stroked72Blazer 1/2 ton status
    Nov 9, 2002
    352
    Little Rock, AR
    If the MSD distributor you were having problems with was a MSD Billet or a MSD Pro-Billet then it is likely the reason it wasn't working properly is those two distributors are ment to be used with MSD 6,7, or 8 series ignitions. These are all capasative discharge systems (CD) which fire two times for each cylinder provideing a more complete burn. If you were using one of these distributors without the CD ignition box it would definatly cause problems.
    In my new Summit there is a new Mallory Aluminum distributor with all the features of the Proform mentioned abouve but made by Mallory. The summit part # is MAA-8548201C for 159.88 or 132.95 without the coil.
  8. dyeager535
    26,980
    Wow, looks like "stock" starts to really fall apart at 4,000RPM. I bet all the racers I know that turn 6000+ on the stock HEI could really wake their motors up! /forums/images/graemlins/rotfl.gif
    Whatever they use as "stock" in that comparison is probably off of a model t, because no stock GM HEI dies off that fast.
  9. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Not sticking up for either of you, but there are more desireable factory parts and modules that can help the HEI.
    Still a good ignition on it's own....
  10. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I've been using a Summit HEI for about 4.5 years now. I paid $150 back then and it has worked flawlessly with my MSD 6AL. /forums/images/graemlins/thumb.gif
