Need New Engine for 85 K5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by df, May 10, 2004.
  1. df
    df Registered Member
    Nov 9, 2003
    13
    New York NY
    85 needs reasonable replacement for tired old 305. Need more power but reasonable $$. Should I replace the carb as well?
    thx
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Just get a simple crate 350 or a stock replacement . Its a lot of fun to build one yourself, but a crate engine is easier. Perhaps some upgrades for durability such as double roller timing chain. Is your carb running well? If it is and you can't do injection, leave it be. /forums/images/graemlins/k5.gif
  3. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    If you are looking for "reasonable", then you might consider a rebuilt 2-bolt main 350 because they cost about the same as a rebuilt 305. That extra 45 (actually more because the rebuilt engine will be bored out more from the stock 350 displacement) cubic inches will add a few more ponies under the hood, and everything from the exhaust and intake manifolds to the accessory brackets will bolt right on to it.
    You can rebuild the carburetor yourself. The one big problem with many old Q-Jet carburetors is the throttle shaft bore on them tend to wear out, and most carburetor rebuild shops do not bother to drill and install a throttle shaft bushing kit in them. One of the symptoms of a worn out throttle shaft bore is if the throttle sticks open a little, thus causing the engine to idle too high. Another symptom is a vacuum leak right at the base carburetor
  4. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    stock replacement crate 350 without intake, carb, distributor (all can be used from the 305) is right around 1200.00 and comes with a 50k mile warranty... tough to beat that.
  5. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    Yea, 2-bolt main Target 350's crate engines are pretty cheap because they are made in Mexico, but will be better than a tired old 305 any day.
  6. Topdown
    Nov 26, 2002
    2,598
  7. 84mudmachine
    84mudmachine 1/2 ton status
    Dec 23, 2003
    184
    Kansas
    I had a new crate Gm 350, and the head cracked on me with less than 1,000 miles on it. It was put in by an individual (non certified), and GM would only cover parts. I would not buy another GM crate engine again after the trouble I had to go through to get them to cover the head. /forums/images/graemlins/deal.gif
  8. df
    Nov 9, 2003
    13
    New York NY
    Hey mud,
    Who has to install for it to be GM certified?
    thx
  9. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    We put a GM 350 long block in my wifes 93 Suburban last fall. I called the GM dealers in the county. Pricing ranged from 1900 bucks to 2500 bucks for the same long block! So I picked up the $1900 one, factory warranty, we switched over the accessories, used the skip loader to set it in. You probably want to purchase a new water pump,(GM), and a new offoad trick carb. I suggest this because it will clearly be an improvement to a tired 305, it's reliable, and you don't indicate that you are looking for more than 220 hp. Good Luck. /forums/images/graemlins/grin.gif
  10. df
    Nov 9, 2003
    13
    New York NY
    Thx Burb,
    What kind of carb specifically?
  11. 84mudmachine
    Dec 23, 2003
    184
    Kansas
    An ASE Certified Tech, if not they will not cover labor.
  12. smartpatrol
    smartpatrol Registered Member
    Feb 6, 2002
    86
    Ault CO
    I would go visit the junkyard and pull an older Q-Jet and rebuild it. I am not convinced yet that the $400 "Off-Road" carbs are any better than a good old Quadra jet. I just installed a rebuilt carb on my Cad 500 in my blazer and it ran flawlessly this past week in moab.
