Need NP203 Input Shaft
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1bigk10, Dec 20, 2001.
  1. 1bigk10
    1bigk10 1/2 ton status
    Dec 20, 2001
    151
    Medford Oregon
    I Need an SM465 Model 203 input shaft to build my Transfercase doubler? Or do I have to change my tranny tailshaft?
    1982 K10 Silverado. [​IMG] 327 SHPE powerplant SM465/205,15"custom lift 38.5"TSL/SWAMPERS 12boltrearD44 front,3.73 gears.
  2. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    i read here that it is available
    did you find an adapter?
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Have you checked the ORD tech page on Doublers? Tons of good info there...
    <a target="_blank" href=http://www.offroaddesign.com/catalog/doubler.htm>http://www.offroaddesign.com/catalog/doubler.htm</a>
  4. 1bigk10
    Dec 20, 2001
    151
    Medford Oregon
    I am making a custom adapter I just need to know the difference between the available input shafts if there is any dfference. [​IMG]
  5. michaelm
    Feb 2, 2001
    872
    yes tons of differences
    rare 4 speed one coarse 10 spline
    th350 27 spline
    th400 32 spline
    go check the ORD site
  6. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    I have already done this mate and I can tell you that there's a couple of ways to do it. First you need either find a rare 465/203 combo which was made only in 1974 or you need to find an output shaft with 32 splines and get a 203 that used to mate to a 203. I chose the second route since the spline count on a 465/203 mate is only 10 splines and extreamly rare. It's a lot of hard work and when you satr buying pieces of transmissions and transfers the price really gets up there. Also, if you decide to change the output shaft on the 465 like I did, there's two different lengths of shafts and they're only 1/8 of an inch different. If you take out a short one and put in a long one, your gears will be sloppy and vise versa the gears will be too tight. After all this said and done, you need to find a rare 465/203 adapter, which I already said was only made in 1974 and the 32 spline output shaft is teice as long as the adapter, therefore you need to either have a machine shop shorten the shaft,(which costs too much) or build a spacerand lenghten the adapter by 4.25 inches. As you collect the pieces for it you will see what I'm talking about.
    As I'm sure you wanted, I chose this setup for strength and the only way to keep the overall strength in the system is to change shafts. Thus gives you 30+ splines all the way to your drive shafts and once together, shouldn't ever have to come apart again. I just got done mating my together and once it's up in the truck and running I'll do a post on it.
    <blockquote><font class="small">In reply to:</font><hr>
    <font color=red>My Wife:</font color=red>"Only two minor cosmetic problems: The inside and the outside!"
    <hr></blockquote>
    1972 K5 502CB,465,203/205Doubler,14FF/D60
  7. Batmanjr
    Mar 23, 2001
    1,537
    BTTT
    <hr></blockquote>
    1972 K5 6.5L,465,203/205Doubler,14FF/D60
  8. 1bigk10
    Dec 20, 2001
    151
    Medford Oregon
    Is the 10 spline shaft a male or female shaft?
  9. RGF
    RGF 1/2 ton status
    Jan 5, 2001
    281
    Maine
    Theres a guy in the For Sale section selling one of those rare SM465 version 203s with the adapter,think it was rfg or something like that?!?[​IMG]
    RGF
  10. 1bigk10
    Dec 20, 2001
    151
    Medford Oregon
    Thanx a bunch man i go see?
  11. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Give us a call, there's a couple ways to go here, you can use a 465 for a NP208 and mount the 32 spline 203 up to it really easy.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
