Need NP203 Shifter
Discussion in 'Rocky Mountain Region' started by whiteiron, Nov 6, 2006.
  1. whiteiron
    whiteiron Registered Member
    Nov 6, 2006
    14
    Rio Rico Arizona
    Cannot get into 4 lo. Can get it in from underneath, shifter does not go that extra mile for 4 lo. I don't need the linkage just the shifter.
    Got one coming. Thanks
  2. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Before replacing, have you tried spraying lube up into it see if it frees up? They are NOTORIOUS for this when they dry out.
  3. whiteiron
    Nov 6, 2006
    14
    Rio Rico Arizona
    Yes. Iv'e tried all the suggestions so far still no go. I have a lead on a replacement so I'll try that. Thanks.
  4. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Why don't you just twin stick it? We used to have a 203 and the mechanism destroyed itself. I took the stock lever and bolted it to one of the linkages and fabbed up another lever and bolted it to the other linkage and never looked back.
  5. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    Twin Stick Build
    Don't throw your old shifter away - Here is a pretty good article to build a twin stick for the 203 using two 203 shifters if you are interested.
    203 How to build Twin Shift
  6. whiteiron
    Nov 6, 2006
    14
    Rio Rico Arizona
    Thanks for the suggestion. I printed out the "how To" from AZ79K5Project. I'm hoping the shifter I have coming will do the trick. If not I'll try the rebuild to a twin stick.
  7. justhorsinaround
    Sep 16, 2003
    6,798
    Oh well fine!!!!!!! Completely disregard the same sorta idea that I posted. I know no one cares. I'll just go crawl under a rock now.:doah:
    Ko. Whatever. I'm back now. It did work out pretty well for us.:D
    Laugh dangit!!!!:haha:
  8. whiteiron
    Nov 6, 2006
    14
    Rio Rico Arizona
    The response I posted was for justhorsinaround and my thanks is genuine. The How To, however, gives me the pictures. I've not done any fabricating of parts nor have I figured out how the shifter I have actually works either. I took apart a junker and for the life of me I couldn't see how that spring loaded rod engages the lever to get into low.
  9. justhorsinaround
    Sep 16, 2003
    6,798
    Well look at it this way. When ya get the other shifter just rob the lever and go to town!
