Need oil pressure readings...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lowlevell, Nov 8, 2001.
  1. lowlevell
    lowlevell 1/2 ton status
    Jun 27, 2000
    343
    Central Ohio, USA
    I need some feedback from you guys/girls, I need to know what your oil pressure is at idle and average off idle pressure.Recently mine has dropped from the mark between 30 and 60, and is now at 30(idle), and 35(off idle). My truck has recently turned over 200,000 miles too. Please let me know what your average pressure and mileage is on your engine, thanks.
    89' burb (almost 3/4 ton) 350 TBI, 700r4
    P.S. The readings i need are for after the engine is warmed up.
    One From None
  2. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    My motors have made or do make 30 at idle, and no less than 45 off idle. You still have good pressure but I would be concerned about a sudden change. Did you change type of filter, oil weight, oil mfg etc recently? Do you have any odd noises or smoking??
  3. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    my new 454 puts out 55 at idle, and about 80 when running. my K20 with its ancient 350 only puts out about 10 PSI at idle, and about 45 when cold, and 30 when warm. (strait 30 in the 454, and 20w50 in the K2o's 350... I live in Arizona, and that watery crap you guys call 10w40 just doesn't cut it when its 110+ outside...) I figgure the engine is either ancinet with worn mains, slopy because its really a racecar engine with loose mains, or has a worn oil pump in it. I plan to replace the oil pump soon here, and hopefully that will increase my flow from nothing at idle.
    if your pressure dropped suddenly, I'd look into it. if your pump is going, then you can replace that easily, and check your mains at the same time.
    good luck,
    -Rich
    My truck isn't ugly, you have a skewed sense of beauty
    <font color=blue>2007 Ford XLS++ intrepid Ram Superduty 7000 R-type's suck</font color=blue>
  4. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    I had a similar problem with my Burb...turned out to be that damn FRAM I used just because it was in my garage and it saved me a trip.
    NEVERMORE...and my pressure sits at 30 or a touch below at idle, a little above 30 off-idle. That worthless filter dropped it down to 15 off-idle.
    The learning curve is a toll road...ride with someone who has already paid!
    <a target="_blank" href=http://photos.yahoo.com/abshort1>U.S.S. Nimitz II</a>
  5. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    My 350 TBI with 115K on it has 40 psi cold idle and almost 50 cold off idle. But when it is warmed up to temp, 20 in drive when hot, and 35ish when driving, If I just get off the highway after doing 65+ for a while, and come to a stop, the pressure will be 15. I have a mechanical autometer guage so these are accurate. I use 10W-40 oil and the factory GM filters.
    Ben 87 Jimmy
    <font color=blue>Rust=Bad</font color=blue>
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I have 30 on idle, and about 45 driving. Pretty stock 350 with 150K on it
    90K5
  7. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    The old man's '89 with a crate motor that has less than 1,000 miles on it does 60 on the cold mornings. 45 around town, and 15-20 at idle.
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  8. lowlevell
    Jun 27, 2000
    343
    Central Ohio, USA
    No smoking, every once in great while a lifter will stick. No abnormal noises. I did use a fram oil filter this time, i usually dont use fram.Looks like most of you guys are in the same pressure range as me.Thanks for the feed back. Gonna use diff. filter next time.
    The Burb also has a factory oil cooler on it.
    One From None
  9. Predator
    Predator 1/2 ton status
    Jun 19, 2001
    130
    OKC,OK
    Ditto Blazer Boy's pressures for me on a rebuild with less than 300 miles.
    My K5 Buildup: <a target="_blank" href=http://www.geocities.com/gettin_deep>http://www.geocities.com/gettin_deep</a>
  10. prjt_blzr
    Mar 4, 2001
    352
    COS, CO
    Did the pressure change happen with the oil and filter change? If so, I would change the filter soon.
    Good luck,
    Mike
