Need opinions and info
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by outlaw612, Oct 18, 2001.
  1. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Cant decide what to do, go to a 465/205 combo or a 700/205. If I went to a 700, it would be a Raptor or equivalent. Im leaning towards the 465 but Im worried about the performance in the mud and on trails. How big of an issue is the clutch slipping when bogged in mud or when climbing? How difficult would the 465/205 be to install in my 82 blazer(currently a th350/208?)
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    All I know is its alot easier to navigate the trails with 2 pedals rather than 3. On the street I love 3 pedals. [​IMG]
    Surgeon General's Warning:
    Viagra and steroids may be harmful to your spouse![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  3. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    I've never had my clutch slip in either mud or trail conditions. As for worrying about 3 pedals instead of two...well I'm hardly ever on the clutch. If it dies on me I just hit the start button without taking it out of gear. It fires right up in gear and continues up the trial. The disadvantage is trying to shift in the mud...it usually results in lack of momentum and getting stuck. You just have to get to know what gear will do it for you. I find second gear low range works good for my truck in the mud...
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    I am an auto guy, but the 465 has a lower first gear and virtually indestructable....... I would personally pick an auto though
    Mike
    <font color=green>"1024x768x256... Sounds like one mean woman."</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  5. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Biggest problem with the clutch in the mud is when you try to shift with it burried. Then it gets gunked up and wont engage correct. I have seen it a few times. Pain in the ass.
    Ken H.
    '85 K5 in process
  6. dyeager535
    26,975
    I would think mud would cause some problems, but I'm wondering if a lot of those problems aren't because people always remove the inspection plate/clutch cover, and don't put it back on. I know I'm not running one, but in mud, the bellhousing opening would be a big giant scoop for the mud.
    I'll defend the 700, but I will never say that it will outlive an SM465 : ) OD is nice, but just get bigger tires and reduce axle ratio if you are really worried about RPM's or mileage.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  7. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    I put a 465/205 in my 82 about 6 months ago it all went in ok.The pedals and clutch linkage was the hard part.All the bolt holes are already there so everything bolts in.I used the manual linkage so i had put a hole in the floor for the clutch rod and cut a hole for the shifter.I swapped everything out of a 77 i bought just for this reason so i had all the parts i needed along with drive shafts.i did still have to have the front shaft shortend 2 inches but the rear shaft fit. SHOULD HAVE USED HYDR.CLUTCH but theres always next time
    A BIG HAMMER CAN FIX ANYTHING.... [​IMG]
  8. Dip Stick
    Dip Stick Registered Member
    Oct 14, 2001
    73
    Murdock, Florida
    I would go with 465, mainly cause i have always like manuals over autos because there is less slipage. But an auto does have an advantage, mainly how fast it shifts and you don't have to always be thinkin about what gear to be in and playin with the clutch when crawling over stuff. If you want a bullit proof auto with od then invest in an 4L80. Almost identical to a Turbo 400 but with od.
    I dunno, just my 2 cents
    <font color=red> It's not what you drive, it's how you drive it</font color=red>
    1986 K20 & Lots of Rust
  9. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    All depends on how you like to wheel. Some guys live and die with 3 pedals and other say it sucks. I personally like the auto. Let's me concentrate on other things rather then clutch engaugment... plus w/ 2 knee rebuilds and a 3rd in the near future, the only clutches I'm going to be using is matched to a Lenco [​IMG]
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
