Need opinions
Discussion in 'The Garage' started by Z3PR, Jan 30, 2005.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Clicky
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Hmmm
    Prolly needs an Edelbrock intake,cam and carb.
    :grin: :grin: :grin:
  3. sweetk30
    Nov 1, 2004
    25,549
    543
    horseheads , ny 14845
    opinons are like a holes every one has or is supost to have one , so do you still want mine?:D
  4. sweetk30
    Nov 1, 2004
    25,549
    543
    accelerator pump? or mabey bad torque convertor?
  5. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Could be a # of things that would cause that. Plugs, timing, fuel starvation, vacuum leak. Process of elimination. I just went thru it with my truck and I still have a lil issue......If I let it warm up fully via choke, truck runs like a raped ape, but if I rev it up and kick the choke off right as the temp gauge passes 115 it will really bog down. Changed the plugs, timed it, lowered tghe idle a bit. then found a vacuum leak at the carb base gasket.
