Need Part # for 3.73 speedo gear
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RAY, May 14, 2002.
  1. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    Does any one know the part # for a speedo gear for 3.73 gears? This would save me alot of time.
    thanks,
    Ray
  2. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    For my 208 it was the orange gear for 3.73 w/ 31s and the green gear for 3.73 w/ 33s. Depends what tire size you are running. I'm not sure if the gears are different for the different cases or not, but if you want the number for the green gear I have, I can dig it out for you.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Spedo gears are color coded.
    Here's a handy site with most all the info you need: <a target="_blank" href=http://www.tciauto.com/tech_info/speedo_gears.htm> TCI spedo Gear Info</a>
  4. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    If I understand this chart correctly, the DRIVE gear is the one inside the tcase on the shaft while the DRIVEN gear is the one in the end of the speedo cable that connects into the tcase. Is this correct? I have a 208/700 combo.
  5. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    That would be correct tx85.
  6. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Ray..
    I have a spare one.. I bought a kit from Gm.. and they sell 2 gears in the kit..
    It should be a light green gear..
    Let me know..
