Need part # for Column Bearings
Discussion in 'The Garage' started by Stickseler, Oct 25, 2004.
  1. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Anyone know the part # for the steering wheel Column Bearins or re-build kit?
    I found out where the 2 shims go but the the bearings fell out /forums/images/graemlins/doah.gif I guess they needed to be replaced anyway /forums/images/graemlins/dunno.gif
  2. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    I thought I did but I can't find the invoice. You can get the bearings in the ignition rack kit. It has the rack and the plastic gear for the ignition switch and it has the 2 bearing that go in the tilt bowl. I think it was only like 20 or 30 bucks from the dealer.
  3. dyeager535
    26,980
    Sorry, no part number in the illustration catalog, but the "SPRING KIT, Tilt Upr" is group 6.521, at least for a tilt wheel/column shift AT.
    That kit includes:
    Pin, Pivot;
    Race, upr sft & brg;
    Seat, upr brg Inr race;
    Retainer, spr;
    spring, whl tilt;
    guide, spring
    Out of the '85-88 C/K/R/V parts manual. All 4 years of those are covered in the above description.
  4. Stickseler
    Mar 23, 2001
    6,503
    Northern Virginia
    Thanks, I'm going to call the dealer in the AM
  5. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    I have the part# for the bearings for a tilt column. Here are some # off my rebuild kit. It is dealer only. GM#7844651
    P/N 784-4651
    www.gmgoodwrench.com
    Have Fun
  6. dyeager535
    26,980
    OUR PRICE: $26.26 gmpartsdirect.com
  7. Stickseler
    Mar 23, 2001
    6,503
    Northern Virginia
    Is that the same as the one you listed above? @ gmpartsdirect it calls it a "rack kit" is that everything I need like you listed above?
  8. Stickseler
    Mar 23, 2001
    6,503
    Northern Virginia
    Do you have the # for the whole rebuild kit?
  9. k5blazerus
    Apr 22, 2001
    654
    Bend, OR
    That part # is for the entire rebuild kit. Ignition rack a plastic gear 2 bearings and 2 shims and a spring
  10. dyeager535
    26,980
    Just plugged in the number posted before, 7844651
  11. Stickseler
    Mar 23, 2001
    6,503
    Northern Virginia
    Thanks /forums/images/graemlins/thumb.gif
