Need part number help for D44
Discussion in 'The Garage' started by mrk5, Jan 4, 2006.
  1. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    I'm going to install my Aussie locker this weekend and one of the things they instruct you to check is the condition of the side gear thrust washers. Since I need to get this complete by the close of the weekend, I would like to just buy a new set and be done with it.
    Anyone have a part number for them? Or someplace local that would carry them. I tried the dealership and they had them on the drawing, but no list for them.
    Any help would be appreciated.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I couldn't find any in my town either for my 12 bolt . I called these guys and had some sent to me http://www.drivetrainspecialists.com/
    They have d44 parts too
    I tried ratech once , but the idiots sent washers for the spiders :rolleyes:
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Are you talkin about the thrust washer that is next to the spindle bearing?
    If so you can get it by buying a Spindle repair kit. Spicer # 706527X
    Kit includes spindle bearing, thrust washer (grey plastic washer) & seal.
    If this is not what your after I have no clue....:D
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    We are talking about the steel shim between the side gears and the inner case in the diff . Years of open diff use usually wears em thin .
  5. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    See if there is a Dana/Spicer distributor near you. They should have it
  6. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    When I did ball joints I tried to find a Dana/Spicer dist here before with no luck.
    It just occured to me that I have 3 D44s I could search for parts. The '74 I'm working on, plus a '75 and a '76. Wonder what the odds are that I could find 2 good thrust washers between the 3 axles.:thinking:
  7. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Find a local shop that works on the drivelines of medium and heavy duty trucks. They will almost always be able to order Spicer parts. Look in the yellow pages under "truck parts".
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Truthfully , I did the install on supersize75's front d44 , during the time it was k5redneck's d44 . I reused the old thrustwashers . No problems on that one .
    I don't believe its gonna be much of a problem on a front .
    Unless you were to drive highway speeds with the hubs locked on pavement and turn a corner ;)
  9. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    www.partsmike.com is really helpful for this stuff and gets stuff to me here in 2 days.
  10. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    Thanks for all the assistance guys.
    I'll check the Yellowpages again.
    I thought about partsmike and forgot to check.
    I also found another vendor, completeoffroad.com They have the thrust washers in question. Plus alot of other cool Spicer stuff too, alot of stuff I would classify as "hard to find" I did some searching about the site, and it looks to be a good vendor; mostly known in the Bronco circles it would appear. Also a vendor on Pirate.
    Pauly, you know if I don't have spare thrust washers lined up, I'll need them. If I have, I won't. You know how that goes.:rolleyes:
