Need parts. Local
Discussion in 'Rocky Mountain Region' started by Hossbaby50, Feb 2, 2004.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I need to find 2 parts for my truck.
    1. transmission shifter linkage. The long rod that runs vertically down the fire wall. TH350 or 700R4.
    2. Drivers side D44 knuckle. I need to find a D44 drivers knuckle that was off a chevy so it has the 3 bolts for the steering arm. I need this local to make sure it matches my passenger knuckle that is off a Ford or Jeep. Thanks
    Harley
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I may still have the shifter linkage off my truggy. You just need the part that goes from the column to the pivot?
  3. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I bent the longrod that runs vertically down the firewall to the pivot point. If you still have it I have to drive to PV High School tomorrow night so i have to go right past your house to get there. What do you want for it? thanks
    Harley
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    If I can find it, you can have it. I'll try to look later tonight, call before you come by in case I have not had a chance to look. Tonight I'll be working late...
  5. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Ive got a complete D44 out of my 70 Jimmy with drum brakes you can have for $70, its in great shape, not sure if the knuckle from it would work or not though???
    Jeff
  6. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I prolly got this.... does the tie rod enter from the top or the bottom.
    Marv
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    looks to be from the top. Thanks Marv
    Harley
  8. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Doh! /forums/images/graemlins/doah.gif
    The one I've got enters from the bottom... /forums/images/graemlins/frown.gif
    Marv
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I was at Jeff's ( bigyellowjimmy ) house tonight and he has a open-knuckle d44 ( drum brakes!? ) with flat top knuckles . It had 3 bolt drivers side for arm , and flat top pass. side. /forums/images/graemlins/thumb.gif If you remove drum brakes and hubs shouldn't disc brake hubs fit, since its open knuckle?
  10. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am not really sure about the drum brake knuckle. Anyone know? Thanks
    Harley
  11. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I believe the knuckle would be same since disc were offered in 1970, the year orf the truck it came on. He really needs em gone so I am sure he would pull em and measure for you. /forums/images/graemlins/k5.gif
  12. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    As long as the knuckle has the 6 stud spindle design, it should work. There are also 5 stud versions (read early 44 and ford).
  13. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    The thing I have to worry about is the tie rod. Does it enter from the top or bottom of the knuckle. If it is the bottom I am SOL. thanks
    Harley
  14. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Would they both be the same from side to side? All I really looked at was flattop pass knuckle, and it DID go through the top /forums/images/graemlins/thumb.gif
  15. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    Harley I took a few photos of the knuckle but cant figure out how to post them on here /forums/images/graemlins/confused.gif, would be happy to email them to ya if you want
  16. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    works for me
  17. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    email coming at ya /forums/images/graemlins/thumb.gif
  18. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I just got an answer to my question if the knuckles are the same. Apparently the spindle bolt holes are clocked differently which makes them not work correctly for a disc setup, so on that note I will have to pass. thanks though, I appreciate it.
    Harley
  19. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    No problem, but I always heard you could convert from drum to disc by simply bolting disc brake hubs on?? Maybe not. Good luck on your search.
  20. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Hows that work ? [ QUOTE ]
    [/ QUOTE ] Does that just mean your backing plates would be in different position ?
    Wondering in Mesa, /forums/images/graemlins/thinking.gif
