Need pics of 12x15s on a K5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudstud, Jul 8, 2002.
  1. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Would like to see how far they stick out. What size tire (width wise) do you run with this wide of a wheel. You think 12.50s would look silly/be safe?
  2. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    Not all 12" wide wheels have the same offset. How far they stick out will depend on the offset of the rim, so make sure you get offset or back spacing when you look at pictures. A wheel that sticks out is really safer than one tucked way under the sheet metal (wider is better...), all else being equal. Too wide causes other problems, though like added stress on wheel bearings/ball joints and greater tendency for the rubber to find sheet metal.
  4. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    Thanks, that helps. Is that 3.5" back spacing then cuz it looks like it's 6 lug (1/2ton)? I'm looking at 3 month old MT tires on 3/4ton wagon wheels for a great price. I'm looking to go 3/4ton sometime soon so just thought I'd look into it before I buy. I didn't know what that tire size would look like on that rim- just don't want the wheel wider then the tire if it comes down to having 12.50s on a 12" wheel for awhile. I guess this combo would make it easier to break a bead though. Hmm.
  5. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Thats not your rig your link is pointing to! /forums/images/icons/mad.gif
    Thats mine! /forums/images/icons/grin.gif
    Bill C /forums/images/icons/cool.gif
  6. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    Hey, whats going on. When I click on your pics my webshots come up??? /forums/images/icons/confused.gif
  7. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    LOL! Same here! It takes me to my control panel.
    BTW I have 12s on mine for now. They are mounted to 38s but take a look if you want.
  8. rodzzilla
    953
    Grinnell, IA
    BS is 4". The wheels are stock ralley's widened 4". 3/4 tons will stick out more due to the wider front axle. I had 12" Bart Monster Wheels on the 79 3/4 ton that I had before the Suburban. They had 3" BS, and was running 35x15.5 15 Swamper TSX's. There was Damn near as much of the tire sticking out of the fender as was covered. /forums/images/icons/shocked.gif Had to lift it to 6" and still cut a major portion out of the fender in order for them to clear. You should not have any problems w/ a 12.5 on a 12.
  9. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    <font color="red">Opps</font color> , <font color="blue">Dang</font color> , had it pointing to my control panal page instead of the public front page. It should be corrected now. Now everyone can see my truck pics. /forums/images/icons/wink.gif Please accept my apologies. /forums/images/icons/blush.gif
  10. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    The only problem that could arise is when you air down. The tires could come off the bead easier if you have wider wheels, I run a lot of sand a spend most of my offroad time aired down, and I run 8x15 wheels with 33x12.50 tires.
