Need pic's of a K5 with 38.5x15", 37" or 35" bogger's???
Discussion in 'The Garage' started by stangfootball34, Nov 30, 2004.
  1. stangfootball34
    stangfootball34 Registered Member
    Aug 21, 2002
    27
    Need pic\'s of a K5 with 38.5x15\", 37\" or 35\" bogger\'s???
    I really need a picture of a K5 running those bogger's. I just want to see and hear from someone how they perform off road and what size of the tire it actually is on a full size rig and what rim they use???
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: Need pic\'s of a K5 with 38.5x15\" bogger\'s???
    They're about 36" tall. If you have a D60 and want good sized boggers, I'd suggest the 39.5s.
  3. i_am_a_sheep
    i_am_a_sheep Newbie
    Nov 30, 2004
    Montana
    Bleat!
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    baaa baaa black sheep
  5. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Bleat!
    great... another one. /forums/images/graemlins/doah.gif /forums/images/graemlins/shame.gif
  6. mr_beer
    mr_beer 1/2 ton status
    Sep 10, 2004
    325
    Mt. hermon LA
    /forums/images/graemlins/screwy.gif /forums/images/graemlins/screwy.gif /forums/images/graemlins/screwy.gif /forums/images/graemlins/screwy.gif
  7. stangfootball34
    Aug 21, 2002
    27
    pic's????
  8. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    This is seventyK5's Jimmy. These are about 37" tall on a 16.5x9.75 rim. I'm sure he'll post up when he see's this.
    This is on about 6" of lift. /forums/images/graemlins/thumb.gif
  9. stangfootball34
    Aug 21, 2002
    27
    Thanks for the pic's. Those really look small, almost like my 35x12.50's. It could be the rim size that makes them look like that though.
  10. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    They look fairly taller than my 35x16 boggers. /forums/images/graemlins/screwy.gif
  11. stangfootball34
    Aug 21, 2002
    27
    I just want to find a medium between the 39.5's and the 35" boggers and I guess the 38.5" bogger is them. So I guess I'll be getting some when the next pay day comes around.
  12. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I don't see anything in your sig and nothing in your profile....what do you have? Do you have the power, lift, and the drivetrain to support 39.5's? That is the size I would run. I also wouldn't rule out the 35x16 if the 39.5 is too large and don't like the 38.5. The 35x16 is taller than the 35x14.50, is wider than the 38.5x15.50, and has the same tread depth and huge lugs as the 39.5.
  13. stangfootball34
    Aug 21, 2002
    27
    1990 Chevy /forums/images/graemlins/k5.gif with a 350TBI, recently rebuilt 700r4, np241, dana 60 up front that's open and a 14 bolt with a detroit. Right now I have 35" bfg mud terrians. oh ya the only thing that sucks is the 4.10's which I will be going to 5:13's or 4.88's when I get the money. Would you recommend the 37x13" bogger over the 38.5x15"? I don't know what it is about the 38.5x15" boggers but the tread looks like a normal mud tire nothing really special. I dunno it could be the picture though. So would you say the look at getting the 35x16" or 37x13" /forums/images/graemlins/confused.gif
  14. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    It depends on what you want. I like my 35x16's because they match my engine's power well and I don't have a frontD60 that hangs down, just the 14BFF so I hve a little less mud to push. I also like wide tires because I have 16.5x14 welds.
    Are you looking for heigth or width? With the 39.5 you will get both. The 37x13 is fairly tall but skinny. I think the 38.5 just a hair taller but a little wider....but still not as wide as the 35x16.
  15. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    37" 13.00x16" boggers on 8"x16" champion beadlocks. [​IMG]
  16. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    [/ QUOTE ]how tall and wide do those measure out
  17. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    Here's 37x13x15 on 15x10 steel rims with 6" lift.
  18. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    Re: Need pic\'s of a K5 with 38.5x15\", 37\" or 35\" bogger\'s???
    The green jimmy (mine) Has 38.5x15x16.5 boggers which measure out to 37.4x14.3x16.5 on a 16.5x9.75 rim. I will be running a 37x13x17 on a 17x9 rim. With 6 inches a lift plan on trimming with 38.5's. I will be dropping to 37's which measure 36.3 and adding about another inch of lift.
  19. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    JK5 is/was running the 38.5x15 Boggers on his K5 and I saw them in person. The tread looked like the usual Bogger pattern (big and mean), and they appeared to be very similiar in height as my 13/38-16 TSL's. My 13/38's measure small for a 38, but I know they are a LOT bigger than the 35x12.50 MT/R's I had before. I had the fenders trimmed for absolutely no tire rub on the trail with the swaybar unhooked, yet couldn't even turn the wheels on flat ground without hitting the fenders after installing the TSL's.
  20. stangfootball34
    Aug 21, 2002
    27
    Cool deal, I just wanted to make for sure the tread was as big and mean as all the other bogger's before I spent the money on um. Tim said the 38.5x15" bogger's measured 36"'s tall. Hmmm 37.4" and 36"'s is a difference. I guess I'll go with the 38.5x15" bogger's then. /forums/images/graemlins/thumb.gif
